:roll:
Hi there i'm lookin' 4 some help - i have got some super-vcd discs but my Dutch Philips TV only supports PAL. Is there a program i can use to convert these super-vdc discs to PAL and the burn them down on blank discs??
Please relpy
Kind regards
A Rookie from Denmark
Are you sure that you can't change a setting on your hardware player so that it forces output in PAL?
Regards.Michael Tam
w: Morsels of Evidence -
Hey Michael
I only have an regular DVD Player not a DVD ROM - my dvd is connected to my television (Philips) and my tv not supports NTSC. So if i only could convert the discs (now Super-vcd NTSC in to PAL Super-vcd discs) my tv should be able to show the colours now it's Black and White because of the lack of support of NTSC - my DVD support NTSC but my tv dosen't
Kind regards
The Rookie from Denmark
Originally Posted by vitualis -
Phones1:
Are you sure you have a FULLY populated SCART-cable? Cheap SCART-cables sometimes leaves out the pins for enabling NTSC on PAL-TV-sets. I had the problem you describe, B/W-strange resolution, on NTSC-discs. I tried to convert my NTSC VCD's to PAL with no great luck (It's quite a lot of fiddeling). So, I would recomend that you visit your TV-shop tomorrow and buy a full-SCART-cable (make sure all 24pins are connected) and try. If that works, you will have saved yourself A LOT of headache. And your Philips TV-set probably supports NTSC, unless it's more than 10 years old!
HTH
/Wintermute -
Hey Mute
I Will just try that thanks for your reply i'll let you know how it goes. My dvd is not connected by a Scart Cable but by a S-VHS cable. I have allso tried to connect it by a scart cable - without any resulat. My TV is from 1995/1996.
Originally Posted by mute -
Phones,
Take out the user's manual of your DVD player and read it thoroughly.
Most DVD players you can set up so that it will force output to PAL or NTSC.
Regards.Michael Tam
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
Convert PAL to NTSC?
By killerteengohan in forum Video ConversionReplies: 32Last Post: 7th Feb 2012, 11:33 -
How to Convert NTSC to PAL
By Gusto747 in forum Video ConversionReplies: 14Last Post: 19th Aug 2010, 19:52 -
How to convert NTSC to PAL?
By jebinio in forum Video ConversionReplies: 15Last Post: 8th May 2009, 19:03 -
How to convert PAL DV to NTSC (I ONLY have NTSC DV camcorder to play with)
By inspiron2 in forum Video ConversionReplies: 4Last Post: 7th Jul 2008, 21:45
