Every utility i've tried changes the length of the resulting WAV file, this is not good because i am converting this WAV into a WMA for combining with a re-encoded WMV-HD
Headache for some reasons converts a 2 hour and 32 minute AC3 to a 1:22 Minute WAV
Besweet converts it to a 2 hour 4 minute wav (The audio just stops at 2 hours 4 minutes)...
What am I doing wrong? Please help
Results 1 to 14 of 14
If this is a continuation of your other thread ,
https://forum.videohelp.com/topic362417.html#1927004
If recall, WAV files have a 2gb file size limitation. You can cut your AC3 , or WAV file with an audio editor (e.g. audacity)
You can do it in segments, and join with avisynth later. It might look something like this: e.g.
Then plug that into WMNicEncCode:a=DirectShowSource("1.wav",video=false) b=DirectShowSource("2.wav",video=false) a+b -
the .wav file is coming back over 7GB i don't think this is the problem. Unless it's 2GB of audio content being the limitation, man this is turning into a nightmare ... hah...
Thanks for all your help -
Try decoding your multichannel .AC3 with valdec.exe
HTH.Code:[C:\] =>valdec Valib decoder ============= Audio decoder/processor/player utility This utility is a part of AC3Filter project (http://ac3filter.net) Copyright (c) 2006 by Alexander Vigovsky Usage: valdec some_file [options] Options: (*) - default value {ch} - channel name (l, c, r, sl, sr) output mode: -d[ecode] - just decode (used for testing and performance measurements -p[lay] - play file (*) -r[aw] file.raw - decode to RAW file -w[av] file.wav - decode to WAV file -n[othing] - do nothing (to be used with -i option) output options: -spk:n - set number of output channels: (*) 0 - from file 4 - 2/2 (quadro) 1 - 1/0 (mono) 5 - 3/2 (5 ch) 2 - 2/0 (stereo) 6 - 3/2+SW (5.1) 3 - 3/0 (surround) -fmt:n - set sample format: (*) 0 - PCM 16 3 - PCM 16 (big endian) 1 - PCM 24 4 - PCM 24 (big endian) 2 - PCM 32 5 - PCM 32 (big endian) 6 - PCM Float format selection: -ac3 - force ac3 (do not autodetect format) -dts - force dts (do not autodetect format) -mpa - force mpa (do not autodetect format) info: -i - print bitstream info -hist - print levels histogram mixer options: -auto_matrix[+|-] - automatic matrix calculation on(*)/off -normalize_matrix[+|-] - normalize matrix on(*)/off -voice_control[+|-] - voice control on(*)/off -expand_stereo[+|-] - expand stereo on(*)/off -clev:N - center mix level (dB) -slev:N - surround mix level (dB) -lfelev:N - lfe mix level (dB) -gain:N - master gain (dB) -gain_{ch}:N - output channel gain (dB) automatic gain control options: -agc[+|-] - auto gain control on(*)/off -normalize[+|-] - one-pass normalize on/off(*) -drc[+|-] - dynamic range compression on/off(*) -drc_power:N - dynamic range compression level (dB) -attack:N - attack speed (dB/s) -release:N - release speed (dB/s) delay options: -delay_units:n - units in wich delay values are given 0 - samples (*) 2 - meters 4 - feet 1 - ms 3 - cm 5 - inches -delay_{ch}:N - delay for channel {ch} (in samples by default)
eac3to creates the wav file with a length of 1 hour 22 minutes (same as headache).
There has to be a reason for this.... I'll try foobar2000, for the other idea regarding valdec I think I need more information in order to try this (I am kind of a n00b).
EDIT: Tried Foobar2000 it too creates the wav file with a length of 1 hour 22 minutes...
Since this is a commonality across more then one utility... there has to be a setting or something
Hope someone out there knows the answer...
Thanks for all the help guys it's much appreciated. -
I have tried valdec as well...
The output wav file is only 1 hour 9 minutes... there has to be some compression happening or something..
Valdec command i used was:
valdec "f:\audio encoding\name.ac3" -w Test.wav -spk:6 -fmt:1
Anyone have any ideas why it keeps changing the length? the length should 2 hours 32 minutes and 13 seconds (to match that of the movie). -
Try poisondeathray's ac3fix suggestion. I've had good luck demuxing with Tranzcode. Download the following and run the batch file in the same folder as your ac3 file.
tranzcode_0.40_beta.rar -
Hey guys I appreciate all your answers,
It looks like this is a size limitation after all.
The size limit is 4GB this lines up with all the wav length times I've seen thus far. Looks like the only solution is to split the ac3 file then recombine using WMNicEnc..
Unless someone has a better idea for converting AC3 to WMA (without losing 5.1 surround).
No Right Surround Channel when transcoding AC3 -> WAV
By SliceOfHorse in forum AudioReplies: 8Last Post: 21st Aug 2009, 16:29 -
6-Channel Wav to AC3 and DTS
By kerpal in forum AudioReplies: 8Last Post: 9th Feb 2009, 10:10 -
Encoding to WAV (Channel Confusion)
By RabidSmurf in forum AudioReplies: 9Last Post: 11th Jan 2009, 09:06 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 12:23 -
AC3 mono to AC3 2 channel conversion help
By efiste2 in forum AudioReplies: 1Last Post: 21st Jul 2007, 14:06
absolutely not...
