Hi hope you can help. I can play this avi file on my computer just fine. But after encoding it....it starts to be out of sync after about 45 minutes. Gspot renders if fine. checked for bad frames in Virtualdubmod and it says 0 frames masked, 0 frames bad, 0 frames good but undecodable. Does this mean there are no bad frames. I have tryed reencoding it with Xvid and Divx but still doesn't work. Same problem.
Gspot says under stream type: OpenDML AVI, 1 vid frame (42 ms) Split: Yes
Been trying to encode this video forever. Tryed putting audio into wave file and reattaching but no luck.
My first guess would be that you have two avi files and the sync difference occurs where the files are merged.
Aside from that, try a different/better tool. ConvertXtoDVD would be preferable, but you could also use DVD Flick or FAVC. Whenever you have similar issue with different apps, it typcally means there is an issue with your source material.Google is your Friend
Off sync audio problems - is it ripping or encoding?
By kirklt in forum DVD RippingReplies: 3Last Post: 14th Jul 2009, 11:48 -
Higher bitrate encoding causes audio sync issues
By keiron in forum Video ConversionReplies: 3Last Post: 12th Jun 2008, 05:37 -
Encoding yields audio out of sync
By chrisr34000 in forum Video ConversionReplies: 3Last Post: 2nd Jun 2008, 07:21 -
"Play All" caused audio out of sync (DVD Lab Studio, Half-D1)
By iryu in forum Authoring (DVD)Replies: 5Last Post: 21st May 2008, 02:52 -
I am Legend Encoding (Blu-ray) audio sync issues
By Ansuer in forum Blu-ray RippingReplies: 21Last Post: 1st May 2008, 18:54
