I have several DVDs with DTS track on them. I use AnyDVD 6.5.0.7 to rip and AutoGK 2.50 to encode...
In AutoGK's main window I see both AC3 and DTS audio streams. If I select DTS, encoding process gets terminated after a minute or so (right after demuxing and indexing process), saying "EXCEPTION: Audio is not found"
In agk_temp folder I see .d2v file but no audio file.
With AC3 audio selected, everything goes fine, with both .d2v and AC3 file in agk_temp folder.
This happens with all DVDs that have DTS.
I have latest AC3filter installed and the tools I use are all latest version.
Is there another step prior to using AutoGK when working with DTS???
Results 1 to 1 of 1
DTS passthrough using AutoGK
By vdgg in forum Video ConversionReplies: 14Last Post: 21st Aug 2014, 18:03 -
Problem with AutoGK
By onlygk in forum Video ConversionReplies: 18Last Post: 2nd Jun 2010, 06:09 -
AutoGk Problem
By darkdream4 in forum DVD RippingReplies: 2Last Post: 2nd Jan 2010, 06:16 -
encoding with DTS audio stream - Audio not found in AutoGK
By extrabyte in forum DVD RippingReplies: 1Last Post: 7th Jan 2009, 17:42 -
Problem with Autogk
By sunny3220 in forum SubtitleReplies: 3Last Post: 14th Nov 2008, 11:05
