I burned a cd as VCD 2.0 on VCDEasy and when I tried it on my DVD player (Mustek V300) i couldn't see anything!?
The DVD had a light saying that it was reading a VCD, i could even control it but i didn't have image?
I saw that if i record a cd as VCD 2.0 it will be recorded as MPEG1. Is that it??
Can anyone help me??
I'm not faimiliar with VCDeasy, while I prefer VCDwizard (another GUI upon VCDimager).
I suggest you recreate the VCD (maybe something wend wrong in the write-process), I also should recomend you to use CDRdao instead of winCDR or Nero (the last 2 burners 'sucks', excuse my language
). If you get VCDwizard (you can get is at http://www.labdv.com/) you also should search the HELP for cdrdao - in there cdrdao has been explained (a bit).
If you wrote the vcd using WINcdr which your cracked, then be sure WINcdr didn't create a "coaster", which is an unusable cd! -
Betamax replied:
'If you wrote the vcd using WINcdr which your cracked, then be sure WINcdr didn't create a "coaster", which is an unusable cd!'
What does one have to do to make sure one doesn't make a (beer) coaster? There's no icon with the coaster option.....
And still i was able to create a coaster after the burn process was completed succesfully with CDRwin -
nope. But the stange thing is that i once burnt a cd upto 70% which i can read with the PC. Not the standalone DVD player.
Ubi
How to rip a copy protected VCD and then burn to a CD
By c1steady in forum Authoring (VCD/SVCD)Replies: 4Last Post: 17th Jul 2009, 14:11 -
By c1steady in forum Newbie / General discussionsReplies: 3Last Post: 17th Jul 2009, 06:40 -
How can i burn a DVD or VCD with subtitles?
By Krimoon in forum Newbie / General discussionsReplies: 2Last Post: 25th May 2008, 15:41 -
how to convert and burn avi to vcd with cusoft
By brandon334 in forum Authoring (VCD/SVCD)Replies: 1Last Post: 21st Apr 2008, 18:49 -
Burn .avi file to VCD while still retaining subtitles
By Holymoly in forum Video ConversionReplies: 1Last Post: 12th Dec 2007, 21:30
