hi,
can someone write instruction to improving webcam quality with ffdshow
also link would be good
or maybe a software which doing this...:]
actually i think i just have problems with capturing the webcam signals with ffdshow i tyhink its nor read them...
while running ffdshow i add the camers program to ffdshow list but its not doing nothing to the cam video(LIVE VIDEO)...:]
Can you see the video at all? Software or codecs aren't going to change the quality very much. The quality is determined by the camera that is actually filming/broadcasting the image.
Google is your Friend -
why isnt it the same principle as incrasing video file quality...i mean principle...:]Originally Posted by Krispy Kritter
You can't increase the quality of a video file either. Any alterations to the original file, reduce quality. So the only way to produce high quality files is to start with a high quality source.
Web cams have various qualities. You can buy a low resolution, low bit rate web cam and expect to get the same quality picture as a high resolution, high bit rate camera simply by using a better codec.
Quality begins with the source, in this case, the web cam itself.Google is your Friend -
I haven't tried this but it has quite a few features and a few basic video enhancement features...
http://www.download.com/RGS-AvaCam/3000-2348_4-10781953.html?tag=mncol
how to use Sony SR12 as web cam. HELP!
By pftjim in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 10th Jan 2010, 04:15 -
Program needed to record web cam at high quality
By drug3188 in forum Newbie / General discussionsReplies: 4Last Post: 2nd Oct 2009, 16:45 -
What are Good software i can use to record videos with my web cam or camera
By jace89 in forum Capturing and VCRReplies: 0Last Post: 21st Dec 2008, 16:08 -
web cam recorded video problem!
By arikiev in forum EditingReplies: 1Last Post: 19th Jul 2008, 13:58 -
monitor other room via web cam
By d_unbeliever in forum ComputerReplies: 1Last Post: 17th Apr 2008, 03:51
