I am looking for a DTV converter box that fills all the items on my wish list...
Universal Remote
Pass-Through
Black in color, hey, it HAS to match my other equipment, right?
Built-in power supply, no wall-wart
Properly vented
S-video and RCA out
RCA audio and Dolby Digital (Optical or Digital Coax)
I have not been able to find a box with the last item!
Does it exist?
Thank you!
2 DVD, or not 2 DVD, that is the question.
The Channel Master box has digital coax and S-Video out. But is not black and I doubt the audio is 5.1 AC3 since that is banned on CECB's. Probably PCM.
http://www.kiva.org/about -
The Channel Master CM7000 doesn't have analog pass through. It is vented and has an internal power supply. The remote only turns on the CM7000, not the TV. I have one and I have to say the tuner and picture are very good.
If you want S-Video, the CM7000 and a couple of the Apex boxes are the only ones that have it. The Apex DT502 is black, has analog pass-through, and no wall wart. According to some reports, the tuner is not one of the better ones, the remote is poorly made, and the picture may be somewhat greenish. I can't tell you if it has good ventilation or not. Best Buy sells it, so you could go inspect the thing. Seeng as it is black I doubt if ventillation, if present, would be visible any of the online pictures. I don't think it has a remote that can turn on the TV.
DTV TUNER DIGITAL CONVERTER BOX - I need one
By lacywest in forum DVB / IPTVReplies: 14Last Post: 31st May 2011, 02:59 -
DTV Converter Features I want with it
By lacywest in forum DVB / IPTVReplies: 11Last Post: 24th Jan 2009, 09:31 -
DTV converter box, antenna questions
By Ai Haibara in forum DVB / IPTVReplies: 0Last Post: 28th Jul 2008, 04:54 -
On getting a DTV converter box...
By ahhaa in forum ComputerReplies: 0Last Post: 12th Apr 2008, 12:27 -
From Dolby Digital AC3 to Dolby Digital Stereo and back
By moviebuff2 in forum Newbie / General discussionsReplies: 2Last Post: 23rd Dec 2007, 19:54
