I want to start a project to edit the videos I recorded with my Canon PowerShot A720 with Adobe Premiere CS4.
My problem is that the only thing I know is that the cam records :
30img/s
640x480
avi format
Codec MJPG (?!)
Resolution : 24 bits (what is that?)
Image kind (translation?) : Progressive
Bits/(Pixel*Image) : 1.487
Audio sample rate : 11,024 kHz
I need a little bit of help to chose (choose? Sorry, bad english) the right settings for the sequence as asked when creating a project.
I need Editing mode, Pixel Aspect Ratio, Fields, Audio Sample Rate (not sure which one to chose?) and video preview format but I don't think I have all of this information.
I have already used Adobe many times but I was capturing video right from a camcorder so I didn't have this problem...
_Edit_
Nevermind, I forgot it wasn't like Final Cut, it doesn't matter if the videos I import don't fit the sequence settings.
But FWIW, here is the info about the videos a Canon PowerShot A720IS records :
AVI
640 x 480
30,00 i/s
Audio
PCM
11025 Hz - 32*bits en virgule flottante - Mono
Resolution : 8 bits
Rate : 88.2 kbps
Video
Data rate*: 1,6 Mo/seconde
Pixel aspect ratio*: 1,0
Okay now I decided to use Final Cut Pro instead of Adbe Premiere (because it's faster).
So... what settings do I choose? I try to import my videos but nothing happens. =/ -
This is highly compressed MJPEG video with highly compressed 8bit 11.025KHz mono audio. Try Windows Movie Maker. It will play in VLC.
If you don't have an MJPEG codec, try PicVideo or Morgan MultiMedia (neither free).
Premiere CS4 needs a codec. Premiere Elements 4 probably has it.
FCP is very particular what it accepts and MJPEG isn't on the list.
We are talking very low quality video here ~70x intraframe compressed.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Questions on recording video on Canon PowerShot A800 and memory
By argonvegell in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 0Last Post: 25th Apr 2012, 11:23 -
Canon Powershot video to avi, and then into Vegas 9--no video
By solarblast in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 25th Jan 2012, 15:50 -
Canon Powershot SX230 HS HD video 1080p and 720p..pretty good for a compact
By peggypwr1 in forum Newbie / General discussionsReplies: 3Last Post: 7th Aug 2011, 01:24 -
Canon HV20+ Adobe Premiere Pro CS3
By Martig in forum Capturing and VCRReplies: 2Last Post: 10th Jan 2008, 00:40 -
Canon HV20 and Adobe Premiere Pro 2.0
By Airk in forum Newbie / General discussionsReplies: 0Last Post: 6th Aug 2007, 21:39
