I have a DVD Recorder, it sometimes messes up its recordings at the postprocessing stage and the recording ends up missing...
I am posting this because it might help someone who's looking for another DVD_VR recovery alternative.
I finalized the disc using the dvd recorder (it might be optional but I have yet to try photorec on an unfinalized disc)
ripped to iso
loaded iso as a virtual drive (Daemon Tools)
checked it out, only 700MB of files yet the iso is 4 GB....
used WinDirStat on it (see attached screenshot)
a lot of used space unaccounted for!![]()
used PhotoRec from http://www.cgsecurity.org/wiki/PhotoRec
(it could work directly on real disc but faster from iso + virtual drive)
PhotoRec seems to be controlled mostly with arrows and enter key... this is what I did in PhotoRec:
chose dvd drive
chose non partitioned media (I went with this since UDF isn't listed)
chose the one partition and search
for filesystem, I chose other
browsed to empty folder (windows: to change drive letter keep going to "..")
once inside desired folder, press Y
it recovered one large mpg file, which accounted for the large space used
just to test, I tried playing the .mpg in VLC media player. it managed to be in sync but only because video did not appear right away (VLC media player is smart!)
if I were to demux this to elementary streams now, I'd get sync problems in the editing stage
used ffmpeg to convert to avi:
ffmpeg -i f909952.mpg -acodec copy -vcodec copy tvshows_recovery.avi
opened in VirtualDub
first bunch of frames happened to be drop frames. I selected a range from the first non drop frame to the end of the file
set video to direct stream copy
save as avi: tvshows_clip.avi
back to ffmpeg:
ffmpeg -i tvshows_clip.avi -f mpeg2video -vcodec copy tvshows.m2v
ffmpeg -i tvshows_clip.avi -f mp2 -acodec copy tvshows.mp2
finally its editable in Mpeg2Schnitt without sync problem.
PhotoRec might work better if you run it directly on the disc instead of the iso:
run PhotoRec, get large mpg
ffmpeg -i f16384.mpg -f mpeg2video -vcodec copy tvshows.m2v
ffmpeg -i f16384.mpg -f mp2 -acodec copy tvshows.mp2
load the m2v into Mpeg2Schnitt
if there's audio sync problems, try the virtualdub method above
update: dvd recorder made another bad disc after recording
every dvd device thought it was a blank disc
loaded it into IsoPuzzle, force size: change "Drive Reported" to "-- Free --", defaults to Drive Reported (0 in this case) sectors change to 2295104, saved iso to x:\UNNAMED_VOLUME.iso
photorec can read from files rather than drives. command prompt: photorec_win x:\UNNAMED_VOLUME.iso
ended up with an unexpected filetype (gpg) and fragmented mpeg files
to solve in photorec: went into File Opts, disabled all file types (press s) and selected mpg
now I've got a big .mpg file to edit
Results 1 to 1 of 1
How to convert Blu-ray to standard DVD-Video (or MKV,MP4) using free tools
By Baldrick in forum User guidesReplies: 4Last Post: 22nd Oct 2015, 21:39 -
How to convert any video to MP4 iPod, iPhone, PS3, XboX360 using free tools
By Baldrick in forum User guidesReplies: 74Last Post: 7th Apr 2014, 00:03 -
any free tools for convertering video fo iphone
By jammychueng in forum Video Streaming DownloadingReplies: 2Last Post: 12th Nov 2010, 04:54 -
How to merge/convert Meg2 video and burn to DVD using free tools
By bahjan in forum User guidesReplies: 0Last Post: 22nd Aug 2010, 12:42 -
Need Command Line video joiner (preferably free tools)
By Nintynuts in forum Newbie / General discussionsReplies: 5Last Post: 25th Mar 2010, 18:36
