Quick questions from the rookie that just purchased Roxio Easy VHS to DVD (blue box):
I am downloading movies from both hi8 and miniDV camcorders using S-video and composite audio cables. Video is ok. Having to start and stop recording because I don't think Roxio has editing.
Both cameras have a DV port (4 pin). Do the make a fire wire cable that has a DV on one end and USB on the other that can I plug directly into the computer? If so will that give me a better picture? Or am I getting a digital video signal already through the S video?
I could only find fire wire that has 6 pin to 4 pin. My computer does not have a 6 pin plug.
Thanks - Rookie
	You should be using the IEEE-1394 connection.You don't need the blue box.Originally Posted by rjack
 If you don't have an IEEE-1394 port on your computer add one on a PCI or PC card.
 http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&DEPA=0&Order=BESTMATCH&Descr...tion=IEEE-1394Recommends: Kiva.org - Loans that change lives.
 http://www.kiva.org/about
	Thanks edDV. So the S cable I am currently using is not digital video? Both cameras say digital. If not....
 if I purchase the IEEE, I will then have a better picture (and digital)?
	S-Video is an analog NTSC connection. IEEE-1394 gets you a quality digital connection.Originally Posted by rjack
 For MiniDV, you get an exact first generation copy to the computer of the data on the tape.Recommends: Kiva.org - Loans that change lives.
	Got it. Last question. If I don't need the "blue box", what do I use to edit video after I download video to computer? I don't need anything expensive or with bells and whistles. The Roxio "blue box" doesn't allow for much mid-stream/mid-tape editing.
	For no frills, start with Windows Movie Maker since you already have it. It can do the capture for you, too.
 On XP, you can find it at:
 Start Menu\All Programs\Windows Movie Maker
 I use it when I need to do something fairly simple really quickly.John Miller
  Questions about connecting a DVD Player playing to computer monitorBy Akastn20 in forum Newbie / General discussionsReplies: 2Last Post: 18th Jan 2012, 00:15
  General Computer QuestionsBy mccoady in forum ComputerReplies: 9Last Post: 28th May 2011, 23:44
  Two questions regarding new computer technologyBy snafubaby in forum Newbie / General discussionsReplies: 3Last Post: 22nd Dec 2010, 08:56
  Rookie is closer to making DVDs!By rjack in forum Newbie / General discussionsReplies: 4Last Post: 10th Jan 2009, 17:39
  rookie help/vista issueBy cwb in forum DVB / IPTVReplies: 7Last Post: 2nd Sep 2007, 20:13
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
