When you look at the rip window on Smartripper, you see that it has three "Methods" I guess you would say. They are "ASPI", "DeCSS", and "VobDec". Well, in the settings, you can shoose either ASPI or DeCSS methods, but there is no choice of VobDec. So why is it there, and Grayed out along with the other two in the Ripping window? How do I use the VobDec method with SmartRipper if possible? If it's not possible, then why does it show up there at all, just greyed out?![]()
Nobody know's? Not surprising, otherwise there would be a How-to on it here on this website then, wouldn't there?
Well, if anybody does figure it out, please feel free to enlighten us all.
vobdec is another way to get the encryption key. unlike decss, it doesn't get it directly from the dvd-rom, instead it uses some kind of "crytographic attack" to get the encryption key. i'm not sure if this is completely accurate, but i believe that's wut vobdec was. this allows you to get the encryption key without having your dvd-rom play the dvd first, i believe.
Yea, yea. I already know that. That's why I whant SmartRipper to use the sunuvubiatch!
Wrong m2v file length with SmartRipper
By kenj in forum DVD RippingReplies: 9Last Post: 11th Jul 2010, 18:44 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 20:21 -
SmartRipper -- question about "Search Intensity" setting
By Dr.Rock in forum DVD RippingReplies: 1Last Post: 30th Dec 2008, 14:26
