    Apr 2005
    Houston, Tx.
    Can any one give any pros or cons for using DVDfab HD Decryptor for PSP? I am wanting to buy the program to back up my movies so I can watch them on my PSP. I know there are free versions out there but have been using DVDfab for a while now and would like to buy the full version.
    I am very new to converting to PSP so I have a few questions. First is it at all possible to burn a movie onto a mini dvd and play it in a PSP? Or does the PSP use a different media then a mini dvd? Second if it is okay to do this what screen size and resolution would be the best? If I cant use mini dvd's and need to save them on my memory stick what screen size and res would work best for a small 1G card?
    Thanks,
    Robert
  2. Member yoda313's Avatar
    Jun 2004
    The Animus
    I'm sure you can't get recordable discs for the psp. That is not what sony is known for - user friendly RECORDING capability.
    They are UMD - universal media discs. Not cdr. Even if a mini cd or dvd-r was the exact same size they are a different file structure from what I understand.
    You could search the net for recordable umd media but I'm sure there is nothing out there. Even if there were you'd probably have to buy a special burner and its probably not worth it.
    I think you should invest in a larger memory card for one. Try used on ebay or something. That would let you use a better bitrate.
    Personally I haven't used dvdfab hd decrypter much to give an honest evaluation.
    I do own corel dvd copy 6 (payware) and I like it. I use it for converting videos to my ZUNE. It has a psp setting as well - plus direct to memory card output - if I remember correctly - I don't have a psp so I haven't used that feature.
    Personally I'd stick with something like super for converting. Its free and pretty versatile. But I can understand your desire for an "all in one" package.
