Hi, I've been backing up my DVDs and I noticed that after I strip out all of the unwanted stuff with DVD Remake, the audio track was 551 MB. But then after I run it through DVD Rebuilder Pro with CCE, the same audio track is only 530 MB. Is this supposed to happen? What would be causing this? Any help would be appreciated, thanks!
The audio track for the movie should (and will) be the same size. If some of the stuff you stripped out was in the same VTS as the movie, that might explain it, I suppose. Or maybe something somewhere along the line is calculating the audio size incorrectly. When you play the DVD there's sound all the way to the end, isn't there? And you got close to the final DVD size you were expecting?
I use exactly the same combination of software and newer had a problem with final product.
I would say same as manono, it is either calculation of each software or you did something wrong.
Just try to play DVD and see if everything is OK.
Get audio track from DVD Extra instead of film sound track in VIDEO TS
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 13:25 -
Problem DVD Rebuilder Pro: Is not a ECL for CCE SP Trial Version
By Talayero in forum DVD RippingReplies: 2Last Post: 30th May 2008, 14:25 -
question about CCE Customized Settings in DVD Rebuilder
By jimdagys in forum DVD RippingReplies: 1Last Post: 30th Oct 2007, 05:20 -
DVD Rebuilder Pro & CCE in Multipass VBR mode
By devnulllore in forum Newbie / General discussionsReplies: 12Last Post: 30th Jul 2007, 10:04 -
Best Advanced CCE Settings in DVD Rebuilder
By devnulllore in forum Newbie / General discussionsReplies: 1Last Post: 16th Jul 2007, 12:56
