Currently using compressor to convert the dv-pal qt file to h.264
12fps/med quality/64kbpsMono
then i run the resulting file through Visual Hub
12fps/standard quality/64kbpsMono
trying to get a 30 min edit down to a final file size of 80mb
70% talking heads/rest is cutaways that use slow pans/zooms/static shots
i dont doubt im doing something stupid as i have no experience with compression/encoding other than trial & error experimentation,
any help appreciated,
can provide more detailed settings if needed,
thanks
fcp studio 2
visual hub
mpeg streamclip
toast
qt pro
80 mb/30 min = 2.67 mb/min = 45.5 KB/sec = 364 kbps.
Audio is 64 kbps, so 300 kbps remaining for video.
With just 300 kbps, keep the frame size no bigger than 464x256 (16:9) or 400x304 (4:3), when going with FLV/H.263.
Avidemux Target Size Problems
By FrozenInferno in forum Video ConversionReplies: 10Last Post: 2nd Apr 2011, 15:52 -
Alpha channel video makes for a larger-than-target bitrate flv
By flvvideo in forum Video ConversionReplies: 1Last Post: 3rd Dec 2009, 12:10 -
convertxtodvd target size problem.
By kuzutolga in forum Video ConversionReplies: 8Last Post: 2nd Nov 2009, 17:18 -
xvid target size problems
By Cowabunga in forum Video ConversionReplies: 13Last Post: 16th Jan 2009, 16:11 -
size problem(edit youtube FLV in premiere pro)
By yunakokimama in forum Newbie / General discussionsReplies: 1Last Post: 25th Jun 2007, 10:52
