Is this project feasible ?
Using tools available here, it is possible to do the following with good results ?
I have a Movie in both VHS in PAL format with English dubbed audio, & a DVD in NTSC with Italian Audio with NO Subs. I want to capture the VHS tape with my usual methods & demux the audio and split the DVD and re-author it with the English audio.
Will it be possible to acceptably sync the audio from these 2 very different sources? What programs will I have to use ? Or, is this such a mess that only pro equiptment and a sound engineer could manage it ? Any advice would be appreciated.
There are a few things to consider PAL is 25fps NTSC 29.97fps.
The audio for DVD is usualy ac3 where tape would be wav.
That said, you can try. It will require that the movie on VHS is exactly the same as one on DVD (that means exactly the same cuts), but either way, you will have to use some audio editor to stretch the audio file to fit NTSC. It will take few steps, nothing is guaranteed, but I ,if I was you, would try.
You will have to match start points, but that can be done with audio delay setting.
Can't Mux audio & video streams to MP4 without a problem
By spycam in forum Newbie / General discussionsReplies: 3Last Post: 10th Nov 2010, 17:49 -
Mux many audio & video files to avi
By Urban20 in forum EditingReplies: 3Last Post: 29th Apr 2010, 04:35 -
ASF2VC1 & transcode the audio WMA to AC3, then mux video VC-1 and audio
By tigerb in forum Newbie / General discussionsReplies: 0Last Post: 9th Jan 2010, 09:02 -
MeGUI won't mux it's own sources
By bidomo in forum DVD RippingReplies: 0Last Post: 11th Jul 2007, 14:32 -
How to mux three sources, but delay only two?
By hrpatton in forum ffmpegX general discussionReplies: 11Last Post: 11th May 2007, 18:22
