    Jan 2009
    Pakistan
    i want to convert the video from dull quality to better quality through video converter tool of jet audio.
    how can i do this? is this possible?
    please guide me or simply suggest me a better software that can do this for me.
    configuration of dull quality:
    width 320
    height 214
    AUDIO:
    bit rate 231kbps
    audio sample size 16bit
    channels 1(mono)
    audio sample rate 22khz
    VIDEO:
    data rate 202kbps
    video sample size 24bit
    stream name video2
    when i see the video in small window the movie quality looks fine. but in full screen it becomes blur. i wanna see the movie with the best video quality in full screen mode.
    can this movie be converted in fine quality?
    plz tell me how?
    any software?
    Apr 2004
    Miskatonic U
    Can't be done. You simply do not have enough data to work with. Something like VideoEnhancer *might* be able to double the resolution and keep the image reasonable, but really, it is what it is, and it ain't much.
    Read my blog here.
  3. Besides, 320x214 is 1.5:1, and obviously in an incorrect aspect ratio, 214 is only Mod2, it was made by an idiot, and is fit only for the recycle bin. And with a higher audio bitrate than video bitrate?
  4. Member AlanHK's Avatar
    Apr 2006
    Hong Kong
    You can't get high quality, but you can improve it a bit.
    When it's "full screen" it's being resized on the fly.
    You can get a better result if you use Avisynth and say,
    LanczosResize and perhaps some deblocking and sharpening.
    Here's a script I used on a fairly low res encode to scale it up:
    AVISource("01a.avi")
    DeBlock_DeBlock(quant=20, aOffset=8, bOffset=16)
    UnsharpMask(64, 9, 0)
    LanczosResize(688,448,0,0,320,240)
    AddBorders(16,16,16,16)
    If you don't use Avisynth, try VirtualDub and some of its built-in filters.
