Hi
I have a problem when burning animation films (for the kids)
I have the AVI & used AVI2DVD to encode & have the DVD image, when the image is played back through the preview window of DVDFab it is fine but when burned to a DVD it becomes jumpy but only when panning across the screen, almost as if it's lost some frames,
I've tried Nero on its own to burn the image or the AVI (converted by Nero), the image with DVDFab & also with Active ISO burner all with the same results, speed of burning does not seem to make any difference either.
The AVI's played through the PC are fine too, I don't think it's the DVD recorder as when I allow Nero to encode the AVI its jumpy in their preview window before burning to DVD
Hope someone can help as this is driving me crazy!!!
Thanks![]()
Results 1 to 9 of 9
Cheers Baldrick - here's the info
Should also say this isn't the first animated film that has had these problems
I'm not (knowingly) trying to change from Pal to NTSC doesn't really matter to me which format it is in, this is the joined AVI after using AVI2DVD to join the two original AVI's
Format : AVI
Format profile : OpenDML
File size : 1.32 GiB
Duration : 1h 26mn
Overall bit rate : 2 181 Kbps
Writing application : AVI-Mux GUI 1.17.4, Nov 5 2005 22:53:48
Video
Format : MPEG-4 Visual
Format profile : Streaming Video@L1
Format settings, BVOP : Yes
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Custom
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 1h 26mn
Bit rate : 1 728 Kbps
Width : 720 pixels
Height : 304 pixels
Display aspect ratio : 2.35
Frame rate : 23.976 fps
Resolution : 24 bits
Colorimetry : 4:2:0
Scan type : Progressive
Bits/(Pixel*Frame) : 0.329 -
Which are you making - PAL or NTSC DVDs? If PAL then, depending on how the conversion is done, it could easily account for the jerky playback if it adds a duplicate frame in every 25, thus making for a slight "jerk" or "stutter" every second. I also second the FAVC suggestion, as it does the conversion correctly.
It could be something else, though. -
Update!
Using FAVC & Imgburn burned in NTSC format seems fine, just need to check that it wasn't a PAL selection on the other programs that was causing the problem
Many thanks for you help
Edit:
Looks like it was the NTSC/PAL thing after all - I hadn't realised that Nero was set to PAL by default & didn't give you the option to change as you went through, found the setting changed to NTSC & all sorted!!
Many thanks again guys, much appreciated
Just one more thing for future reference - how can I tell if an AVI is recorded in PAL or NTSC, I've checked the properties & it doesn't say so I'm assuming its FPS or something?? Info above on this particular AVI
Yes. It is the framerate:
Easy to say: If it is 25 fps then it is PAL; everything else (i.e. 23.976 or 29.97) is NTSCGUI for dvdauthor:
https://www.videohelp.com/~gfd/
H.264 conversion/frames missing/skipped
By iGnight in forum Video ConversionReplies: 18Last Post: 29th Jan 2011, 03:23 -
Tivo troubles with missing frames
By Solarjetman in forum Video ConversionReplies: 3Last Post: 12th Jan 2011, 13:50 -
AVI jerky/missing frames?
By MdMa11 in forum Video ConversionReplies: 10Last Post: 26th Apr 2010, 00:13 -
missing frames
By carmatic in forum RestorationReplies: 11Last Post: 19th Feb 2009, 22:06 -
Jumpy playback, dropped frames during capture, CPU pegged to 100%
By tylerz in forum Newbie / General discussionsReplies: 7Last Post: 24th Jul 2007, 18:09
