i have a jvc everio gzhd6 camcorder, and i was wondering how i could lower the frames per second(fps) down, wether this is or can be done in camera, or on the computer, i don't know, but your help is much appreciated
Probably not in the camera, unless it has presets to other fps settings. You could re-encode with software and change it to what you want. Why do you want the change the frames per second? Slow motion effects? Time lapse?
And welcome to our forums.
thanks for the welcome, i want to lower the fps to make my clips more cinematic, the camera doesn't have any fps settings that i know of( can anyone help with that) and how would i " re-encode with software..."
If you are going to convert in post to 24p, shoot from a tripod and limit zooms and pans.
http://www.kiva.org/about -
That's a common misconception. It's camcorder marketing propaganda. Changing your footage to 24fps won't make it look movie-like. Most of the movie look comes from shallow depth of field. Check out the cinematic feel of this clip, taken with a camcorder and a depth of field adapter. The fps doesn't really matter:Originally Posted by aug3r
http://www.vimeo.com/987952
And as edTV mentioned, the stability of shots and slowness of pans is a big factor. -
thanks, i wasn't sure about the fps and it looking cinematic, but i guess i was influenced by the propaganda :), but that clip disproves it i guess it was great, was it shot at a high fps rate? i did read the caption, and your response but im not sure i completely understand what you are saying, so i need to by a " depth of field adapter"?
Yeah, if you want it to look filmic. Do a search on "Letus Mini" or Jag35 or Brevis
Is the FPS of a MiniDV camera higher than the FPS of DVD video?
By granturissimus in forum Newbie / General discussionsReplies: 8Last Post: 9th Jan 2011, 06:40 -
mixing 1280 x 720 29,97 fps and 1440 x 1080 25 fps in final cut
By perik in forum EditingReplies: 6Last Post: 17th Nov 2010, 23:42 -
How to lower the FPS for a MKV file?
By sldvd in forum EditingReplies: 6Last Post: 1st Jan 2010, 10:30 -
What lower end HD camcorder to buy
By avz10 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 7Last Post: 13th Aug 2009, 17:00 -
How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
By Chuba753 in forum Newbie / General discussionsReplies: 7Last Post: 6th Jun 2008, 20:17
