    Jan 2009
    I'm using DVDStyler 1.7.2, which has been working fine for the last few months since I installed it. However, just recently, I've seen the app crash when creating an ISO image. I use .vob files and have done this before with no issues. The errors occurred on 1.7.1 as well, which is why I installed the beta (bad choice, but not the root of the problem).
    DVDStyler v1.7.2 beta 3
    FFmpeg: libavformat 52.23.1, libavcodec 52.0.0, libavutil 49.11.0
    Prepare
    Cleaning temporary directory
    Generating menus
    Generating menu 1 of 1
    Prepare
    Create menu mpeg
    Multiplexing subtitles (buttons) into mpeg
    Executing command: spumux "C:\Temp\dvd\menu1-0.mpg_spumux.xml"
    DVDAuthor:pumux, version 0.6.14.
    Build options: gnugetopt iconv freetype
    Send bugs to <http://www.dvdstyler.de/support.html>
    INFO: Locale=English_United States.1252
    INFO: Converting filenames to CP1252
    STAT: 0:00:00.000
    INFO: PNG had 2 colors
    INFO: PNG had 1 colors
    INFO: Pickbuttongroups, success with 1 groups, useimg=1
    INFO: Found EOF in .sub file.
    INFO: Max_sub_size=842
    INFO: 1 subtitles added, 0 subtitles skipped, stream: 32, offset: 0.50
    Statistics:
    - Processed 0 subtitles.
    - The longest display line had -1 characters.
    - The maximum number of displayed lines was 0.
    - The normal display height of the font arial.ttf was 0.
    - The bottom display height of the font arial.ttf was 0.
    - The biggest subtitle box had 842 bytes.
    Generating DVD
    Executing command: dvdauthor -o "C:\Temp\dvd" -x "C:\Temp\dvd\dvdauthor.xml"
    DVDAuthor::dvdauthor, version 0.6.14.
    INFO: dvdauthor creating VTS
    WARN: First cell is not marked as a chapter in PGC 0, setting chapter flag
    STAT: Picking VTS 01
    STAT: Processing C:\Temp\dvd\menu1-0.mpg...
    INFO: Video pts = 0.500 .. 3.870
    INFO: Audio[8] pts = 0.500 .. 3.860
    INFO: Audio[32] pts = 0.500 .. 0.500
    STAT: VOBU 7 at 0MB, 1 PGCS
    INFO: Generating VTSM with the following video attributes:
    INFO: MPEG version: mpeg2
    INFO: TV standard: ntsc
    INFO: Aspect ratio: 4:3
    INFO: Resolution: 720x480
    INFO: Audio ch 0 format: mp2/2ch, 48khz 20bps
    STAT: Processing C:\Users\Public\Videos\GHCHS Football\DVD Rips\Kennedy.VOB...
    STAT: VOBU 16 at 5MB, 1 PGCS
    STAT: VOBU 32 at 11MB, 1 PGCS
    STAT: VOBU 48 at 17MB, 1 PGCS
    STAT: VOBU 64 at 23MB, 1 PGCS
    STAT: VOBU 80 at 29MB, 1 PGCS
    STAT: VOBU 96 at 35MB, 1 PGCS
    STAT: VOBU 112 at 41MB, 1 PGCS
    STAT: VOBU 128 at 47MB, 1 PGCS
    STAT: VOBU 144 at 53MB, 1 PGCS
    STAT: VOBU 160 at 59MB, 1 PGCS
    STAT: VOBU 176 at 66MB, 1 PGCS
    STAT: VOBU 192 at 71MB, 1 PGCS
    STAT: VOBU 208 at 78MB, 1 PGCS
    STAT: VOBU 224 at 84MB, 1 PGCS
    STAT: VOBU 240 at 90MB, 1 PGCS
    STAT: VOBU 256 at 95MB, 1 PGCS
    STAT: VOBU 272 at 101MB, 1 PGCS
    STAT: VOBU 288 at 108MB, 1 PGCS
    STAT: VOBU 304 at 114MB, 1 PGCS
    STAT: VOBU 320 at 120MB, 1 PGCS
    STAT: VOBU 336 at 126MB, 1 PGCS
    STAT: VOBU 352 at 132MB, 1 PGCS
    STAT: VOBU 368 at 138MB, 1 PGCS
    STAT: VOBU 384 at 144MB, 1 PGCS
    STAT: VOBU 400 at 150MB, 1 PGCS
    STAT: VOBU 416 at 156MB, 1 PGCS
    STAT: VOBU 432 at 162MB, 1 PGCS
    STAT: VOBU 448 at 168MB, 1 PGCS
    STAT: VOBU 464 at 174MB, 1 PGCS
    STAT: VOBU 480 at 180MB, 1 PGCS
    STAT: VOBU 496 at 186MB, 1 PGCS
    STAT: VOBU 512 at 192MB, 1 PGCS
    STAT: VOBU 528 at 197MB, 1 PGCS
    STAT: VOBU 544 at 204MB, 1 PGCS
    STAT: VOBU 560 at 210MB, 1 PGCS
    STAT: VOBU 576 at 216MB, 1 PGCS
    STAT: VOBU 592 at 222MB, 1 PGCS
    STAT: VOBU 608 at 228MB, 1 PGCS
    STAT: VOBU 624 at 234MB, 1 PGCS
    STAT: VOBU 640 at 240MB, 1 PGCS
    STAT: VOBU 656 at 246MB, 1 PGCS
    STAT: VOBU 672 at 253MB, 1 PGCS
    STAT: VOBU 688 at 258MB, 1 PGCS
    STAT: VOBU 704 at 264MB, 1 PGCS
    STAT: VOBU 720 at 270MB, 1 PGCS
    STAT: VOBU 736 at 276MB, 1 PGCS
    STAT: VOBU 752 at 282MB, 1 PGCS
    STAT: VOBU 768 at 288MB, 1 PGCS
    STAT: VOBU 784 at 294MB, 1 PGCS
    STAT: VOBU 800 at 301MB, 1 PGCS
    STAT: VOBU 816 at 307MB, 1 PGCS
    STAT: VOBU 832 at 313MB, 1 PGCS
    STAT: VOBU 848 at 319MB, 1 PGCS
    STAT: VOBU 864 at 324MB, 1 PGCS
    STAT: VOBU 880 at 330MB, 1 PGCS
    STAT: VOBU 896 at 337MB, 1 PGCS
    STAT: VOBU 912 at 342MB, 1 PGCS
    STAT: VOBU 928 at 349MB, 1 PGCS
    STAT: VOBU 944 at 354MB, 1 PGCS
    STAT: VOBU 960 at 361MB, 1 PGCS
    STAT: VOBU 976 at 367MB, 1 PGCS
    STAT: VOBU 992 at 372MB, 1 PGCS
    STAT: VOBU 1008 at 378MB, 1 PGCS
    STAT: VOBU 1024 at 384MB, 1 PGCS
    STAT: VOBU 1040 at 391MB, 1 PGCS
    STAT: VOBU 1056 at 397MB, 1 PGCS
    STAT: VOBU 1072 at 403MB, 1 PGCS
    STAT: VOBU 1088 at 409MB, 1 PGCS
    STAT: VOBU 1104 at 415MB, 1 PGCS
    STAT: VOBU 1120 at 421MB, 1 PGCS
    STAT: VOBU 1136 at 427MB, 1 PGCS
    STAT: VOBU 1152 at 433MB, 1 PGCS
    STAT: VOBU 1168 at 439MB, 1 PGCS
    STAT: VOBU 1184 at 445MB, 1 PGCS
    STAT: VOBU 1200 at 451MB, 1 PGCS
    STAT: VOBU 1216 at 457MB, 1 PGCS
    STAT: VOBU 1232 at 463MB, 1 PGCS
    STAT: VOBU 1248 at 469MB, 1 PGCS
    STAT: VOBU 1264 at 475MB, 1 PGCS
    STAT: VOBU 1280 at 481MB, 1 PGCS
    STAT: VOBU 1296 at 487MB, 1 PGCS
    STAT: VOBU 1312 at 493MB, 1 PGCS
    STAT: VOBU 1328 at 499MB, 1 PGCS
    STAT: VOBU 1344 at 505MB, 1 PGCS
    STAT: VOBU 1360 at 511MB, 1 PGCS
    STAT: VOBU 1376 at 517MB, 1 PGCS
    STAT: VOBU 1392 at 523MB, 1 PGCS
    STAT: VOBU 1408 at 529MB, 1 PGCS
    STAT: VOBU 1424 at 535MB, 1 PGCS
    STAT: VOBU 1440 at 541MB, 1 PGCS
    STAT: VOBU 1456 at 548MB, 1 PGCS
    STAT: VOBU 1472 at 553MB, 1 PGCS
    STAT: VOBU 1488 at 559MB, 1 PGCS
    STAT: VOBU 1504 at 565MB, 1 PGCS
    STAT: VOBU 1520 at 572MB, 1 PGCS
    STAT: VOBU 1536 at 578MB, 1 PGCS
    STAT: VOBU 1552 at 584MB, 1 PGCS
    STAT: VOBU 1568 at 590MB, 1 PGCS
    STAT: VOBU 1584 at 596MB, 1 PGCS
    STAT: VOBU 1600 at 602MB, 1 PGCS
    STAT: VOBU 1616 at 607MB, 1 PGCS
    STAT: VOBU 1632 at 614MB, 1 PGCS
    STAT: VOBU 1648
    at 620MB, 1 PGCS
    STAT: VOBU 1664 at 626MB, 1 PGCS
    STAT: VOBU 1680 at 632MB, 1 PGCS
    STAT: VOBU 1696 at 638MB, 1 PGCS
    STAT: VOBU 1712 at 644MB, 1 PGCS
    STAT: VOBU 1728 at 650MB, 1 PGCS
    STAT: VOBU 1744 at 656MB, 1 PGCS
    STAT: VOBU 1760 at 662MB, 1 PGCS
    STAT: VOBU 1776 at 668MB, 1 PGCS
    STAT: VOBU 1792 at 674MB, 1 PGCS
    STAT: VOBU 1808 at 680MB, 1 PGCS
    STAT: VOBU 1824 at 686MB, 1 PGCS
    STAT: VOBU 1840 at 692MB, 1 PGCS
    STAT: VOBU 1856 at 698MB, 1 PGCS
    STAT: VOBU 1872 at 704MB, 1 PGCS
    STAT: VOBU 1888 at 710MB, 1 PGCS
    STAT: VOBU 1904 at 716MB, 1 PGCS
    STAT: VOBU 1920 at 722MB, 1 PGCS
    STAT: VOBU 1936 at 728MB, 1 PGCS
    STAT: VOBU 1952 at 734MB, 1 PGCS
    STAT: VOBU 1968 at 741MB, 1 PGCS
    STAT: VOBU 1984 at 746MB, 1 PGCS
    STAT: VOBU 2000 at 753MB, 1 PGCS
    STAT: VOBU 2016 at 759MB, 1 PGCS
    STAT: VOBU 2032 at 765MB, 1 PGCS
    STAT: VOBU 2048 at 771MB, 1 PGCS
    STAT: VOBU 2064 at 777MB, 1 PGCS
    STAT: VOBU 2080 at 783MB, 1 PGCS
    STAT: VOBU 2096 at 789MB, 1 PGCS
    STAT: VOBU 2112 at 794MB, 1 PGCS
    STAT: VOBU 2128 at 801MB, 1 PGCS
    STAT: VOBU 2144 at 806MB, 1 PGCS
    STAT: VOBU 2160 at 813MB, 1 PGCS
    STAT: VOBU 2176 at 819MB, 1 PGCS
    STAT: VOBU 2192 at 825MB, 1 PGCS
    STAT: VOBU 2208 at 830MB, 1 PGCS
    STAT: VOBU 2224 at 837MB, 1 PGCS
    STAT: VOBU 2240 at 843MB, 1 PGCS
    STAT: VOBU 2256 at 849MB, 1 PGCS
    STAT: VOBU 2272 at 855MB, 1 PGCS
    STAT: VOBU 2288 at 861MB, 1 PGCS
    STAT: VOBU 2304 at 867MB, 1 PGCS
    STAT: VOBU 2320 at 873MB, 1 PGCS
    STAT: VOBU 2336 at 879MB, 1 PGCS
    STAT: VOBU 2352 at 885MB, 1 PGCS
    STAT: VOBU 2368 at 891MB, 1 PGCS
    STAT: VOBU 2384 at 897MB, 1 PGCS
    STAT: VOBU 2400 at 903MB, 1 PGCS
    STAT: VOBU 2416 at 909MB, 1 PGCS
    STAT: VOBU 2432 at 915MB, 1 PGCS
    STAT: VOBU 2448 at 921MB, 1 PGCS
    STAT: VOBU 2464 at 927MB, 1 PGCS
    STAT: VOBU 2480 at 933MB, 1 PGCS
    STAT: VOBU 2496 at 940MB, 1 PGCS
    STAT: VOBU 2512 at 945MB, 1 PGCS
    STAT: VOBU 2528 at 951MB, 1 PGCS
    STAT: VOBU 2544 at 957MB, 1 PGCS
    STAT: VOBU 2560 at 963MB, 1 PGCS
    STAT: VOBU 2576 at 969MB, 1 PGCS
    STAT: VOBU 2592 at 975MB, 1 PGCS
    STAT: VOBU 2608 at 981MB, 1 PGCS
    STAT: VOBU 2624 at 987MB, 1 PGCS
    STAT: VOBU 2640 at 993MB, 1 PGCS
    STAT: VOBU 2656 at 999MB, 1 PGCS
    STAT: VOBU 2672 at 1006MB, 1 PGCS
    STAT: VOBU 2688 at 1012MB, 1 PGCS
    STAT: VOBU 2704 at 1018MB, 1 PGCS
    STAT: VOBU 2720 at 1024MB, 1 PGCS
    STAT: VOBU 2736 at 1030MB, 1 PGCS
    STAT: VOBU 2752 at 1035MB, 1 PGCS
    STAT: VOBU 2768 at 1042MB, 1 PGCS
    STAT: VOBU 2784 at 1048MB, 1 PGCS
    STAT: VOBU 2800 at 1054MB, 1 PGCS
    STAT: VOBU 2816 at 1059MB, 1 PGCS
    STAT: VOBU 2832 at 1066MB, 1 PGCS
    STAT: VOBU 2848 at 1072MB, 1 PGCS
    STAT: VOBU 2864 at 1078MB, 1 PGCS
    STAT: VOBU 2880 at 1084MB, 1 PGCS
    STAT: VOBU 2896 at 1089MB, 1 PGCS
    STAT: VOBU 2912 at 1096MB, 1 PGCS
    STAT: VOBU 2928 at 1102MB, 1 PGCS
    STAT: VOBU 2944 at 1108MB, 1 PGCS
    STAT: VOBU 2960 at 1114MB, 1 PGCS
    STAT: VOBU 2976 at 1120MB, 1 PGCS
    STAT: VOBU 2992 at 1126MB, 1 PGCS
    STAT: VOBU 3008 at 1132MB, 1 PGCS
    STAT: VOBU 3024 at 1138MB, 1 PGCS
    STAT: VOBU 3040 at 1144MB, 1 PGCS
    STAT: VOBU 3056 at 1150MB, 1 PGCS
    STAT: VOBU 3072 at 1156MB, 1 PGCS
    STAT: VOBU 3088 at 1162MB, 1 PGCS
    STAT: VOBU 3104 at 1168MB, 1 PGCS
    STAT: VOBU 3120 at 1175MB, 1 PGCS
    STAT: VOBU 3136 at 1180MB, 1 PGCS
    STAT: VOBU 3152 at 1186MB, 1 PGCS
    STAT: VOBU 3168 at 1193MB, 1 PGCS
    STAT: VOBU 3184 at 1198MB, 1 PGCS
    STAT: VOBU 3200 at 1204MB, 1 PGCS
    STAT: VOBU 3216 at 1210MB, 1 PGCS
    STAT: VOBU 3232 at 1216MB, 1 PGCS
    STAT: VOBU 3248 at 1222MB, 1 PGCS
    STAT: VOBU 3264 at 1229MB, 1 PGCS
    STAT: VOBU 3280 at 1235MB, 1 PGCS
    STAT: VOBU 3296 at 1240MB, 1 PGCS
    STAT: VOBU 3312 at 1246MB, 1 PGCS
    STAT: VOBU 3328 at 1253MB, 1 PGCS
    STAT: VOBU 3344 at 1259MB, 1 PGCS
    STAT: VOBU 3360 at 1265MB, 1 PGCS
    STAT: VOBU 3376 at 1271MB, 1 PGCS
    STAT: VOBU 3392 at 1277MB, 1 PGCS
    STAT: VOBU 3408 at 1282MB, 1 PGCS
    STAT: VOBU 3424 at 1289MB, 1 PGCS
    STAT: VOBU 3440 at 1295MB, 1 PGCS
    STAT: VOBU 3456 at 1300MB, 1 PGCS
    STAT: VOBU 3472 at 1307MB, 1 PGCS
    STAT: VOBU 3488 at 1313MB, 1 PGCS
    STAT: VOBU 3504 at 1319MB, 1 PGCS
    STAT: VOBU 3520 at 1325MB, 1 PGCS
    STAT: VOBU 3536 at 1331MB, 1 PGCS
    STAT: VOBU 3552 at 1337MB, 1 PGCS
    STAT: VOBU 3568 at 1343MB, 1 PGCS
    STAT: VOBU 3584 at 1349MB, 1 PGCS
    STAT: VOBU 3600 at 1355MB, 1
    PGCS
    STAT: VOBU 3616 at 1361MB, 1 PGCS
    STAT: VOBU 3632 at 1367MB, 1 PGCS
    STAT: VOBU 3648 at 1373MB, 1 PGCS
    STAT: VOBU 3664 at 1379MB, 1 PGCS
    STAT: VOBU 3680 at 1385MB, 1 PGCS
    STAT: VOBU 3696 at 1391MB, 1 PGCS
    STAT: VOBU 3712 at 1397MB, 1 PGCS
    STAT: VOBU 3728 at 1403MB, 1 PGCS
    STAT: VOBU 3744 at 1409MB, 1 PGCS
    STAT: VOBU 3760 at 1415MB, 1 PGCS
    STAT: VOBU 3776 at 1421MB, 1 PGCS
    STAT: VOBU 3792 at 1427MB, 1 PGCS
    STAT: VOBU 3808 at 1433MB, 1 PGCS
    STAT: VOBU 3824 at 1440MB, 1 PGCS
    STAT: VOBU 3840 at 1445MB, 1 PGCS
    STAT: VOBU 3856 at 1451MB, 1 PGCS
    STAT: VOBU 3872 at 1457MB, 1 PGCS
    STAT: VOBU 3888 at 1463MB, 1 PGCS
    STAT: VOBU 3904 at 1469MB, 1 PGCS
    STAT: VOBU 3920 at 1476MB, 1 PGCS
    STAT: VOBU 3936 at 1482MB, 1 PGCS
    STAT: VOBU 3952 at 1488MB, 1 PGCS
    STAT: VOBU 3968 at 1494MB, 1 PGCS
    STAT: VOBU 3984 at 1500MB, 1 PGCS
    STAT: VOBU 4000 at 1506MB, 1 PGCS
    STAT: VOBU 4016 at 1512MB, 1 PGCS
    STAT: VOBU 4032 at 1518MB, 1 PGCS
    STAT: VOBU 4048 at 1524MB, 1 PGCS
    Assertion failed: p>=s->vi[i-1].sectpts[1], file src/dvdvob.c, line 1321
    This application has requested the Runtime to terminate it in an unusual way.
    Please contact the application's support team for more information.
    WTF?!
    Whether you think you can or can't, you are probably right. - Henry Ford
  2. ...I use .vob files...
    Vob files may be used in dvdauthor, but it is not recommended as vob files may have content which is not supported by dvdauthor (like SCR resets). I would demultiplex the vob files and retry.
