Hi all. I just installed FF, no errors. Trying to encode .mov into flash video. I select the video, pick my settings, etc., press Encode, and it's done in one sec with a 0KB file. Original .mov file is 20MB 3 min long. Any idea why this is happening?
Thanks!
Results 1 to 12 of 12
I turned off audio, so simplify things a bit, here is what I get when I look at details (blue 'i'):
FFmpeg version CVS, Copyright (c) 2000-2004 Fabrice Bellard
Thu Jan 8 13:05:47 CST 2009
Mac OSX universal build for ffmpegX
libavutil version: 49.0.0
libavcodec version: 51.9.0
libavformat version: 50.4.0
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x5597b8]negative ctts, ignoring
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/tatiana/Desktop/IntroToApp.mov':
Duration: 00:03:00.4, start: 0.000000, bitrate: 930 kb/s
Stream #0.0(eng): Audio: aac, 44100 Hz, stereo
Stream #0.1(eng), 30.00 fps(r): Video: h264, yuv420p, 1024x768
Codec type mismatch for mapping #0.0 -> #0.0
- It now says "Failed"
Encoding started on Thu Jan 8 13:41:52 CST 2009
Output #0, flv, to '/Users/tatiana/Desktop/IntroToApp.mov.ff.avi.flv':
Stream #0.0, 29.97 fps(c): Video: flv, yuv420p, 1024x768, q=2-15, 940 kb/s
Stream #0.1: Audio: mp3, 48000 Hz, stereo, 128 kb/s
Stream mapping:
Stream #0.1 -> #0.0 [sync #0.0]
Stream #0.0 -> #0.1 [sync #0.1]
[mp3 @ 0x54340c]flv doesnt support that sample rate, choose from (44100, 22050, 11025)
Could not write header for output file #0 (incorrect codec parameters ?)
bench: utime=0.013s
/Applications/ffmpegX_0.0.9y/ffmpegX.app//Contents/Resources/flvtool2:2:in `require': no such file to load -- flvtool2 (LoadError)
from /Applications/ffmpegX_0.0.9y/ffmpegX.app//Contents/Resources/flvtool2:2
Thanks for the tip (doh!
But now it produces blank files
I used VisualHub, and that works better...
Thanks for your help!
Could you post the logfile for this latest attempt? And how big is the file that is produced? Is it still 0kB?
If it's a more or less normal-sized file, it could be ok, but there might be a playback problem. What player did you use to view it?
And yes, VisualHub is a great tool!
I am having the same issue. Here is my output:
Encoding started on Fri Jan 23 17:10:04 PST 2009
[mov,mp4,m4a,3gp,3g2,mj2 @ 0x4701fc]negative ctts, ignoring
Seems that stream 1 comes from film source: 2997.00 (2997/1) -> 29.97 (30000/1001)
Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/Users/joeboldt/Documents/bizqwick/master gardeners/Master Gardener Segments/Eugenia_Psyllid.mov':
Duration: 00:07:57.5, start: 0.000000, bitrate: 2763 kb/s
Stream #0.0(eng): Audio: pcm_s16le, 48000 Hz, stereo, 1536 kb/s
Stream #0.1(eng), 29.97 fps(r): Video: h264, yuv420p, 600x400
It does convert to other formats.
Thanks for any help
Converting to FLV doesn't play nice with 'Invert mapping' in ffmpegX.Originally Posted by JoeBoldt
Try reversing the streams in QuickTime Pro before converting, so that 'Invert mapping' won't be needed.
Check out Jeroen Wijering's FLV Player, a Flash file that links to FLV files of your choosing, and presents a player interface on a web page.Originally Posted by JoeBoldt
Compress large FLV file to a smaller size FLV file
By RustyBob in forum Video ConversionReplies: 1Last Post: 26th Oct 2011, 18:21 -
How to trim .flv file without re-encoding
By Eye for Video in forum Newbie / General discussionsReplies: 7Last Post: 31st May 2010, 01:01 -
Problem with artifacts when encoding to FLV using ffmpegX
By Leon_Cych in forum ffmpegX general discussionReplies: 2Last Post: 30th Apr 2010, 08:57 -
Encoding to .FLV but just black in converted file??? Help me please!!!!
By mkettle in forum ffmpegX general discussionReplies: 1Last Post: 15th Feb 2009, 19:32 -
How to find encoding info of a Flash video (.flv) file?
By Netozai in forum Newbie / General discussionsReplies: 2Last Post: 9th Oct 2007, 15:35
