hey recently i got annoyed at how much a dubbed show had changed from the original (and my friend not believing me).
if possible i would like to know a program that can help me have the 2 videos play at eh same time in the same video (of course at a lower resolution) eg. vid1 on top left and vid2 on bottom right withy black boxes in the other 2.
could anyone suggest a program that could help me do this as painlessly as possible, i also need to be able to pause one at times i choose to keep them in sync (deleted scenes)
thanks in advance (this is also a personal goal to count the amount of "necessary editing" that made the show in question nothing like the original) if u want a example i can like a youtube vid if you wish from one i found once
sorry if this not in the right section didn't know where to put it![]()
Buy My Books -
Keep in mind that the processing time an personal energy involved in making your side-by-side video may vastly exceed the required effort to simply play the videos on 2 separate hardware units. If you or your friend has a laptop or portable DVD player, you could bring it into the same room where DVD movies are watched on TV. By eyeballing and carefully using the pause buttons of the 2 units, you can closely synchronize the starting points of the two videos and let them run.
Just an alternative suggestion. -
As gadgetguy suggested, you don't have to make anything except for the script. No effort, no reencoding. Just open the script in some player that supports AviSynth scripts, like MPC. As an example, assuming 1.33:1 videos and an AVI source:Originally Posted by filmboss80
A=AviSource("C:\Path\To\Video1.avi",False)#false disables the audio
B=AviSource("C:\Path\To\Video2.avi",False)
A=A.LanczosResize(320,240)
A=A.AddBorders(0,0,320,0)
B=B.LanczosResize(320,240)
B=B.AddBorders(320,0,0,0)
StackVertical(A,B)
Adjust for your names and paths. It can be played like any other video. You can't pause each individually, though, although the script can be adjusted for the editing of each video (like to remove certain sections).
Player to play 2 separate videos side by side for 3D effect ?
By andy15star in forum Software PlayingReplies: 9Last Post: 21st Jan 2012, 13:52 -
How to put two videos side by side
By Videographer in forum EditingReplies: 3Last Post: 12th Oct 2011, 21:57 -
Combine 2 Videos Side by Side
By bseos in forum EditingReplies: 7Last Post: 19th Jun 2011, 12:34 -
Merge 2 FLV video files side by side
By zsuppguy in forum Newbie / General discussionsReplies: 3Last Post: 7th Jan 2010, 17:58 -
Device for 2 videos side-by-side on TV?
By ehusted in forum Portable VideoReplies: 10Last Post: 18th Nov 2009, 02:10
