Hi, is there any software encode or re-encode RM to RM?
I have a RM/RMVB stand alone player in my living room. I copy my RMVB (no problem playing in computer) to the player but I could only see video but no audio.. however.. I copy another movie in rmvb format but it didn't have any problem playing the rmvb file..
It might because my stand alone does not have the codec for the audio.. so I may need to re-encode..
any solution?? preferred RM to RM conversion.
				Results 1 to 9 of 9
	The standalone might support cook audio (or RA8), which is the "usual" audio
 There are new versions like RA10 which is similar to AAC which it probably doesn't support
 You can use Easy RealMedia Producer to convert (free). I don't think you can just swap the audio (i.e. you have to re-encode both video & audio), so there will be quality loss for both.
	Using RM Muxer
 http://forum.doom9.org/showthread.php?s=&threadid=86264
 which can both demux and mux real files (you can combine video from one and audio from another if you wish)
 you can probably get away with just recoding the audio
	poisondeathray: I installed EAsy RealMedia Producer and found out there are many types of RA8.. which one should i use?? I have tried one but somehow it does not have audio too..
 mgh: am I just need to demux and mux them? do I need another program to convert the audio before i mux them?? if there is another software needed, what software is that?
	demux audio and video
 play one of the files which plays perfectly on your standalone player in rm player and check details
 encode audio as per that
 mux new audio with video-burn to rw-check on your standalone player
	mgh: not really quite get you. I understand I have to demux the audio and video.. and convert the audio to another code such as "cook" (i think) and mux the new audio with video so that I can play it perfectly.
 mgh: the demuxed audio is "atrc" code (I use DTDrive to demux and it showed that). so I need to re-encode them to "cook" right?
 I still couldn't find a conversion software to convert it.
	Use mediainfo (view=>text) on a file that does work to determine what audio is compatible with your standalone player
 The default preset 64kbps stereo music - RA8 is the standard cook audio compatible with virtually everything that supports Real Audio.
 It might be that your player doesn't work or is broken, if the file works on the PC fine. I have a standalone unit that plays rmvb/rm as well, and it does work with RA8
	How did you fix the problem, so others can benefit from your experience?
  accounting software for Mac bookkeeping software for MacBy Noahtuck in forum Newbie / General discussionsReplies: 1Last Post: 30th May 2017, 14:43
  Why does this movie playing software not work? (Bluray software)By oz_surfer in forum Software PlayingReplies: 5Last Post: 31st May 2010, 04:18
  EasyCap Video Capture Software - No Picture On Software ScreenBy Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 20:26
  Developing software that uses opensource or GLP softwareBy wiseant in forum ProgrammingReplies: 4Last Post: 10th Sep 2009, 09:07
  media server software to stream to my HTPC, What software works the best toBy onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 22:45
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
