Hi all,
My computer has K-Lite Codec Pack and XviD4PSP. I used XviD4PSP to convert a DVD to an avi file, and it cannot be played back if I uninstall the K-Lite.
So could you please help me how can I convert a DVD to a single and normal avi file, which can be played on a normal computer (using Windows Media Player) without installing any other extra codec pack?
I prefer to use XviD4PSP as the encoder than others because I think it's free and it could bring up an excellent quality, just like the ex in this topic https://forum.videohelp.com/topic355179.html so pls help me with XviD4PSP!
One more thing, I know in XviD4PSP, there is a place to choose avi as output format, but it has up to 7 different kinds. So please help me how to choose the right one and how should I change the video/audio setting to have such a good quality?
Pls forgive me my English, thank you!
If you want it to play back on a standard Windows XP install with no other codecs, then you have ot convert it to either mpeg-1, or WMV. Aside from a very small collection of basically useless alternatives, everything else needs a codec.
Best option would be to
a) ditch k-lite and every other codec pack before it ruins your system
b) install either FFDShow, or VLC or The KM Player for playback
c) Convert to AVI (Hardware) in Xvid4PSP, which is Xvid tuned for standalone player playbackRead my blog here.
Thanks for answering, but I still remember one time I could open an avi file by using WMP without installing anything, so there is really no way to do that, I just want it to be an avi format.
The K-Lite, is there anything bad with it, I have used it some months ago and it include the FFDShow also, so should I remove it and install only the FFDShow?
Thanks for suggesting me using the AVI Hardware option, but why there are some many other options in it? Is AVI Hardware used for playing back on computer? -
AVI Hardware is specifically designed for playback in standalone DVD recorders that are Divx certified or support mpeg-4 (ASP) playback. Yes, it will playback on a PC that has Xvid installed.
There is a very small range of codecs for the avi container installed with windows, and they are, frankly, rubbish. They compress poorly and are not much use unless you are happy with large file sizes or low resolution.
WMV is the standard for Windows out of the box playback. Mpeg-1 has the widest adoption for no-codec-required playback.Read my blog here.
How can I convert a walmart security video .avi(sn40 codex) to normal video
By DrBaheim in forum Newbie / General discussionsReplies: 20Last Post: 14th Jan 2025, 19:58 -
How To Convert Nero Digital Video To Normal DVD?
By Laz Baz in forum Authoring (DVD)Replies: 11Last Post: 6th Feb 2012, 05:59 -
3 gb avi file containing 1 min of footage, is it normal ?
By codemaster in forum EditingReplies: 2Last Post: 2nd Jan 2012, 11:46 -
720 FLV file to normal avi?
By jake25uk in forum Video ConversionReplies: 3Last Post: 17th Jun 2010, 18:46 -
cannot convert downloaded file in xvid4psp
By suevee in forum Newbie / General discussionsReplies: 2Last Post: 4th Aug 2009, 19:55
