I`m from the U.K. and I was trying to play a region 2 dvd on an American friends philips dvd 711 player. It`s an old machine but in perfect condition besides the fact that I used what appears to be a bad region 2 hack that has left the player locked and with a rolling screen. If this was my player I wouldn`t give a crap but I would like to fix it for my friend. Any help will be greatly appreciated![]()
Rolling screen constantly ?
I suspect it isn't the region hack, but the fact that you tried to play a PAL R2 and not an NTSC R2 disc. The player is now outputting a PAL signal to a NTSC TV, hence the rolling. If you have the manual (and for some reason American's never seem to have the manual - don't know why), find the instructions for changing the output to NTSC and try to fly blind. Otherwise you may have to pull the power cord from the wall and let it sit for an hour to see if it resets itself.
Failing that, you will have to plug it into a TV that accepts PAL input so you can see the menus and change it back to NTSC.Read my blog here.
It just tells me that the disc doesn't match the region coding of the player. Looks like I'll be reimbursing the players owner :,-(. Ahh well, better luck next time, I guess.
These are some comments on that player. It will play both formats, but only on respective TV. That is PAL on PAL, NTSC on NTSC.Read features: Price: Time used: Rating:
CDR
CDRW? DVD-R?
DVD-RW?
DVD-R DL? DVD+R?
DVD+RW?
DVD+R DL? VCD
XVCD?
XSVCD? SVCD
SVCDSubs?
SVCDTracks?
MP3
WMA
CVD? $200 N/A 9 of 10
Comments:
Bought this player 3 years ago and boy am I glad. This machine is built like a tank. It is located in our 3 year-old's room and it sees daily use and abuse - and I mean abuse! (like climbing on the machine, loading discs halfway etc...)
Never broke down and plays anyting I throw at it - VCDs, SVCDs of various brands (but only if authored to standrd). Very advanced features for its time: plays PAL and NTSC (but no conversion). Component video outs, both optical and coax audio outs, and DTS.
Only drawbacks are no MP3 playback and the remote ergonomics are so-so. Overall was a great buy in 2000, although you can probably find better ones today. For my next player I will definitely consider Philips. -
It is considered BUTCH to not read manuals.
PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
Euroline DVD100 DVD Player Region all region code/hack?
By mjgjhb in forum Newbie / General discussionsReplies: 0Last Post: 21st Jul 2011, 09:26 -
Samsung BD P3600 Bluray player, Firmware version 2.12, Region Locked?
By DM242 in forum DVD & Blu-ray PlayersReplies: 4Last Post: 25th Sep 2010, 15:35 -
Pioneer DV-220KV-K DVD Multi Region Player is totally locked!!
By Vandor in forum DVD & Blu-ray PlayersReplies: 0Last Post: 16th Feb 2010, 08:09 -
NON-region DVD player hack...
By cwb in forum DVD & Blu-ray PlayersReplies: 10Last Post: 24th Sep 2009, 16:53 -
Microvision In Car Dvd Player - need region hack please!
By vanishingbluepoint in forum Newbie / General discussionsReplies: 0Last Post: 27th Sep 2008, 18:38
