Hi All
I don't have a HiDef TV or a Blu-ray writer or a Blu-ray player but I want to try encoding some HD video
I can use my brother's Blu-ray player or his Pioneer MPEG4 player with his HD TV to view clips
What I am wondering is what format to use to burn to a DVD-R (as data - not DVD format) and what resolution I should aim for
I would like to preview clips on my 21" Sony CRT Monitor as well
TIA
	https://www.videohelp.com/hd
 https://www.videohelp.com/tools/multiAVCHD
 RipBot264 would be an easy way to encode the files to Blu Ray specs
 Burning Blu Ray media onto a DVD is referred to as "BD5" for a single layer DVD and "BD9" for a dual layer DVD.
	I would guess that his Pioneer player won't do anything for you. It will most likely only play standard definition source, even if it upscales to 1080i for display.
 What will be your source ? If your source is standard definition material, or worse, downloaded sub-SD Divx/Xvid files, then you will have to upscale them in software first to HD resolutions, encode them to AVC, then author them for bluray playback. This also assumes that your brother's BD player will play AVCHD discs - not all do.
 MultiAVCHD is one method, TSmuxer is another. Both will output AVCHD structures ready for burning with Imgburn. Neither of them will do any encoding for you.
 I suggest you start small and download a few 1080p and 720p quicktime trailers from apple, use Xvid4PSP to repackage the content to M2TS files, then use multiAVCHD to create a structure. Burn to a DVD using Imgburn, with UDF set to at least 2.0, and see if it plays in your brother's player. If it doesn't, you haven't wasted time encoding anything.
 If it does play then you can look at encoding material yourself. Xvid4PSP is a relatively simple front-end to some high powered tools and will get you started, however if you are upscaling SD or lower source, you may want to look at VideoEnhancer or similar as well.Read my blog here.
	Thanks guns1inger
 Yeah, I didn't think his Pioneer player would handle anything other than SD
 I did plan on using VideoEnhancer - I have got good results from it - especially when I do some initial upsizing using Spline64Resize
 For sources, I have some commercial DVDs and some 640x480 Interlaced HuffYUV captures
 Time to check out XviD4PSP.
 Do you have a preference re MultiAVCHD or TSmuxer?
	I haven't had a chance to use multiAVCHD. The big difference between the two are menus (multiAVCHD does, TSMuxer doesn't), and multiple titles (Again, mulitAVCHD does, tsmuxer doesn't) Read my blog here.
  Best way to play HiDef camcorder moviesBy Ematte in forum Newbie / General discussionsReplies: 5Last Post: 27th Apr 2011, 20:09
  T2 HiDef PlaybackBy Megahurts in forum Software PlayingReplies: 23Last Post: 11th Sep 2010, 00:16
  Hidef(.mkv) to DVD(.m2v) with Avisynth.By RaChe in forum Video ConversionReplies: 4Last Post: 1st Sep 2010, 16:09
  Transferring HiDef DVC tapes TO ANOTHER HI DEF MEDIUM HD DVD/BlueRay/OtherBy LCC0256 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 23rd Oct 2008, 16:49
  what's the best hidef output file I'ld render to by sony vegasBy perryoops in forum Video ConversionReplies: 5Last Post: 24th Aug 2008, 02:27
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
