    May 2006
    Hi everyone.
    I have a Pinnacle Studio PCTV. as old as the hills vers 1.0 Its working on O/S Win 98se at the moment . What is the best resolution I can get from this device , if I make a VCD or a SVCD from old Vcr Vhs tapes. I am in the process of upgrading this device, to work on XP sp2, if you ever owned an old PCTV vers 1.0 give me a post.
    Cheers visionman
    Health IS the first Wealth------So do not strain your eyes!
  2. Banned
    New York, US
    Originally Posted by visionman
    Hi everyone.
    Cheers visionman
    Regardless of your capture source or hardware, VCD/SVCD is limited to 240 lines vertical resolution.
  3. For PAL VCD capture at 352x288.
    For PAL SVCD capture at 480x576.
  4. Banned
    New York, US
    Those are indeed correct numbers, jagabo. The numbers I quoted are the lines visible on NTSC displays. In any case, for better quality I'd capture the videos with at least 352x480 (interlaced) in mind. But, then, the original post doesn't tell us very much about the source. If the source is standard VHS 4:3 ratio, I'd recommend a final 352x480 or even 704x480 to stay closest to the original source format. VHS is already poor quality; I've never liked the results in SVCD. I suggest VHS-to-digital looks much better with a larger interlaced transfer. But, then, the owner might have have specific reasons for preferring SVCD.
  5. The OP is in the UK, he's likely capturing PAL.
  6. Banned
    New York, US
    Lucky bird, that OP. I spent time in the UK. PAL danced all around our crummy NTSC.
    May 2006
    Hi , jagabo and sanlyn, thanks for the very specific and informative advice. With the PAL defination. Will test your suggestion capturing at higher level sanlyn. Cheers
    visionman
