Hi Everyone,
I have just purchased an unopened (very old) Pinnacle Studio PCTV from a local charity shop. It says on the box for Win 95/98/NT4.0 Can I get this hardware and software to work on an XP sp2 operating system? The hardware IDE card is Version 1.0 and the software is version 3.50 Cheers
visionman
Health IS the first Wealth------So do not strain your eyes!
Hi Bendix G15,
yes I installed it on a Win 98se O/S . It installed OK, Studio working, although the TV is installed its not showing any shows just a blank screen. Does this system need to be activated with a code to activate the TV functions or does it go straight from the install? Cheers thanks.
visionmanHealth IS the first Wealth------So do not strain your eyes! -
Thanks for the link Stiltman, I will check this link out . I didnt see anything with version 1.0 or s/ware version 3.50. This is a really old version of PCTV. Thanks for the advice.Originally Posted by stiltman
I have one of those in a box somewhere. Never could get it to work well under Win98se or XP and wasted many hours trying.
http://www.kiva.org/about -
hI edDV,
Thinking the same thing myself, just thinking to use the capture device . Will probably buy new or 2nd hand ,USB or capture card to work on P4 XP sd2. If you have any suggestion of trouble free devices you could recommend , Im all ears. Cheers and thanks
Software for Pinnacle PCTV usb2
By jodal in forum Media Center PC / MediaCentersReplies: 11Last Post: 28th Apr 2010, 05:32 -
pinnacle pctv 310i
By marc21782000 in forum Capturing and VCRReplies: 10Last Post: 4th Jan 2010, 02:30 -
What software for Pinnacle PCTV HD?
By tomreedtoon in forum Capturing and VCRReplies: 10Last Post: 9th May 2009, 06:14 -
Pinnacle PCTV HD Ultimate Stick
By bigjimmpls in forum Capturing and VCRReplies: 19Last Post: 28th Dec 2007, 14:40 -
Pinnacle PCTV USB 2 - Vista
By hellybelly in forum Capturing and VCRReplies: 0Last Post: 30th Oct 2007, 03:20
