I use Xpress 4.0 (works great) and was wondering if there is an information resource that provides comparisons of the various video formats, pluses and minuses? For example, converting from QuickTime to Windows Media Format produces a larger file and the quality seems to improve.
Thanks! J
What is your goal with the video?
For low file size but with good quality use H264 video and AAC audio, and you can store it in different containers like mov,mp4 or mkv.
And you should be able to specify the output file size by changing the bitrate. Higher bitrate = better quality. -
Objective would be good quality, smaller file size and what is the best format for these.
First you need to separate containers and codecs.
What container you use (AVI, MP4, MOV, MKV, WMV, etc.) will depend on the capabilities of your target playback device(s) -- now and in the future(?). Some containers are rather tightly associated with particular codes (WMV3 in WMV container, for example).
Then you need to consider codecs. In general, any codec can deliver very high quality if given enough bitrate (big enough file size). The bitrate required to deliver quality varies. From least compression to most:
MPEG2 (DVD for example)
MPEG 4 part 2 (Divx, Xvid...)
MPEG 4 part 10 (h.264, AVC...) -
How does this relate to subsequent players of these conversions, do I need to ensure the person I am giving it to can play these formats first or can they be more universal?
Best all round tool to convert video formats, basic editing, etc.
By ian_g in forum Video ConversionReplies: 9Last Post: 16th Mar 2011, 05:21 -
Convert various video formats to 24-bit non-compressed AVI
By koolaidmk in forum Newbie / General discussionsReplies: 3Last Post: 4th Apr 2009, 13:20 -
Is there any efficient and effective tool to convert most of video formats?
By coody in forum Video ConversionReplies: 9Last Post: 4th Feb 2009, 13:28 -
How to convert .scm to avi or any other video formats?
By xmartin86x in forum Video ConversionReplies: 2Last Post: 9th Jan 2008, 10:35 -
Getting 0KB files when trying to convert Real Video to other formats
By j1201 in forum ffmpegX general discussionReplies: 1Last Post: 13th May 2007, 04:34
