  1. Member kpoman's Avatar
    Jan 2003
    I have captured (or transferred) two separate DV files via firewire using the default Windows Vista transfer settings and I believe the files are Type 1 DV avi's. I'm trying to join the two using Virtualdub by selecting "Direct Stream Copy" but get the following error about 5 minutes into the process: "Unable to read audio samples starting at 37017159 from the DV stream." Is there any other way to join these files without too much headache? Thanks in advance.
    Live Long, Play Hard, Think BIG!
    try avidemux and see if it works any better.
  3. Member kpoman's Avatar
    Jan 2003
    Thanks Baldrick. I'll try that when I get home tonight.
