Hi guys.
Sorry for bringing up this old Pal to NTSC conversion again.
I will greatly appreciate if somebody can help me with my problem.
I used this guide "Guide for extracting menus for editing, and reinserting edited menus"
to convert PAL DVD to NTSC with all the menus and extras and everything worked fine, but one thing I can't figure out how to fix.
After inserting buttons into new menu the sub layers not lining up (when highlighting button the highlighting text appears lower and slightly taller) because it still in 720x576 size
So the question is how I can convert the sublayer .sup file from the size 720x576 to 720x480? I use Muxman for remuxing.
Any ideas? [/url]
You can try it with the DVD Subtitle tools:
http://web.quick.cz/FKasparek/Software/DVD/DVDSupTools.htm
Use the DVD Subtitle Decoder to get the BMPs, resize them to 720x480 and then use the DVD Subtitle Encoder to recreate the sup file from the resized images. I'm not sure if this works, as the DVD Subtitle tools are made for 'normal' subtitles and the sublayers are a little bit different.GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
It's been awhile since I converted menus From PAL to NTSC. But the way I handled the subpictures was:Originally Posted by danfisherman
1) Use subrip to rip the subpic BMP's from the menus
2) Used XNView to resize from PAL to NTSC resolution and save as a new BMP(NTSC) file
3) And then I would open up notepad in the same folder where the NTSC BMP file is and use the following:
Where SUB.bmp is the name of your NTSC BMP file. You may have to do a carriage return after the the .bmp file. Then I would save it as an .SST file(which muxman can open).Code:st_format 2 Display_Start forced TV_Type NTSC Tape_Type NON_DROP Pixel_Area (2 479) Display_Area (0 2 719 479) E2 (255 255 255 = = =) E1 (0 0 255 = = =) PA (0 0 0 = = =) BG (255 0 0 = = =) Directory . Color (1 1 1 1) Contrast (0 0 0 0) 1 00:00:00:00 00:01:00:00 SUB.bmp #
4) Use muxman to mux everything including your new .SST file. (after which you can now use vobblanker and pgcedit to complete the transition)
It's been awhile since I've done this so I may have missed something. But I was never able to find an easier way. -
Thank you guys for your help
Unfortunately script didn't work. It looks like it can't locate the BMP file, it muxing but there is no sub picture in the menu at all.
I used DVDSubEdit instead of Subrip to get BMP file of sub pic, but I think it shouldn't make a difference right? -
I do it exactly the same way:
Check the Muxman.log (in the root of the C Drive) for clues as to why it didn't work. Is it 720x480? Is it 4-Bit (16 colors)? Is it named the same as in the SST file? Is the BMP in the same folder as the SST file?Code:st_format 2 Display_Start forced TV_Type NTSC Tape_Type NON_DROP Pixel_Area (2 479) Display_Area (0 2 719 479) E2 (255 255 255 = = =) E1 (0 0 255 = = =) PA (0 0 0 = = =) BG (255 0 0 = = =) Directory . Color (1 1 1 1) Contrast (0 0 0 0) 1 00:00:00:00 00:01:00:00 NTSCWide001.bmp #
DVDSubEdit is a good way to get the BMP. You checked the BMP, right, to make sure the text or icons are there? Sometimes I use DVDSubEdit and just get a solid colored BMP, if I don't do it right. -
I guess this just shows how long ago I did this as I never updated dvdsubedit and didn't know current versions of it can save the subics as BMP's. Although I tested on a PAL movie and I did get a solid color on the BMP. But when I used subrip it extracted correctly.Originally Posted by manono
danfisherman: In addition to what manono said about finding about why it didn't work some other things to check out:
- In XNView (if you used it), during resizing for some reason only bilinear resizing worked for me and saving it as RLE compression.
- During the muxman step, when you import the sst file it should show the filename on there if it reads it correctly. If it doesn't then no filename will show up, at least from the 2 versions of muxman I used. One last thing you could actually do to make sure it imported correctly is to save the project then open the mxp file in notepad and scroll down and look for Item=Sub-Picture Stream. If it is blank then it didn't import, if it shows the code as above then it imported.
But anyway the steps above are pretty much what to do in order to do this kind of conversion as I tried it on a PAL movie just now with success. One other step I didn't mention was I used ifoedit on the vts of the menu to change the menu attributes to NTSC and save. -
I have to ask, sorry,
Why are you doing this in the first place when certain dvd players will play the original on a NTSC TV?PAL/NTSC problem solver.
USED TO BE A UK Equipment owner., NOW FINISHED WITH VHS CONVERSIONS-THANKS
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 12:33 -
Pal To NTSC Menu Conversion
By Mastiland in forum Newbie / General discussionsReplies: 10Last Post: 7th Dec 2010, 14:14 -
PAL DVD to NTSC DVD: CCE is changing resolution (720x480 to 720x576). Argh.
By Colmino in forum Video ConversionReplies: 2Last Post: 9th Jan 2009, 20:15 -
How to convert PAL DV to NTSC (I ONLY have NTSC DV camcorder to play with)
By inspiron2 in forum Video ConversionReplies: 4Last Post: 7th Jul 2008, 22:45 -
What should I do w/ Video OpenDivX4 720x480 24.975 PAL/NTSC? fix or convert
By JoeBolden in forum Video ConversionReplies: 1Last Post: 15th Dec 2007, 23:12
