Results 1 to 12 of 12
    Jan 2009
    Nigeria
    Hi, this software is great, i converted my avi file to mkv and the quality and video is superb, but there is no Audio at all! i mean there is no sound, i ripped my movie twice, once with the tab " Nero AAC " and second time with " Copy Original " you can see the pictures below, so what's wrong ? why the output file doesn't have any sound/audio ?
    Thanks in Advance
  2. Hi billyww
    please .. post the log
    BHH
    HDConvertToX, AutoMen, AutoMKV Developer
    Jan 2009
    Nigeria
    Originally Posted by buzzqw
    Hi billyww
    BHH
    Hi Buzz, thanks for the reply, you mean the log which get appeared when you convert something? i should convert it again tonight ( for the third time! ) to get that log, cause you know i deleted the last file and last log cause there was no sound, i'll post it tomorrow
  4. ok, i'll wait
    BHH
    Jan 2009
    Nigeria
    Hi Buzz, here is the log :
    03:36:28 0.98 - - - - - - - - - - - - - START JOBS - - - - - - - - - - - - - -
    03:36:28 OS Version: Windows XP
    03:36:28 Selected Input file: E:\L1.avi
    03:36:28 Selected Output dir: E:\temp\
    03:36:28 Selected Final Name: 2 1 A 3 4s
    03:36:28 Selected Container type: MKV
    03:36:28 Selected Encoder: X264
    03:36:28 Selected Size: 185 / 1
    03:36:28 Selected Profile: 2_Pass_Balanced.xml
    03:36:28 Selected Resizer: SimpleResize (neutral soft) / Automatic
    03:36:28 Selected Filters: RemoveGrain(mode=2)
    03:36:28 Selected Deinterlacer: AUTO
    03:36:28 Selected Field Order: AUTO
    03:36:28 Enabled CRF/CQ AutoRes at 20 value
    03:36:28 Track Language 1: All Audio Tracks
    03:36:28 Audio Codec 1: Nero AAC
    03:36:28 Audio Quality 1: 0.35
    03:36:28 Audio Channel 1: Stereo
    03:36:28 Track Language 2: NONE
    03:36:28 Audio Codec 2: Nero AAC
    03:36:28 Advanced Audio Settings DUMP Track 1
    03:36:28 Nero Option Profiles: AUTO --- Encoding Mode: Quality
    03:36:28 CCT Option Profiles: AUTO --- Channel Options: AUTO
    03:36:28 Lame Settings: ABR
    03:36:28 Audio Normalization: 1
    03:36:28 Frequency: AUTO --- Tempo: NONE --- Pitch: NONE --- Other Add:
    03:36:28
    03:36:28 Extracting all audio tracks with ffmpeg
    03:36:32 Unable to determine movie properties , switched to DirectShowSource
    03:36:54 Number of Frames: 153307
    03:36:54 Framerate: 29.970030
    03:36:54 Movie length in Seconds: 5116
    03:36:54 Movie Width/Height: 592/448
    04:04:29 Source is declared tff by a margin of 52/54.
    04:04:29 Advanced Deinterlace Routines Log
    04:04:29 Analyzed 919 sections of five frames
    04:04:29 Found Interlace Sections: 3 0.33%
    04:04:29 Found Progressive Sections:914 99.46%
    04:04:29 Found Telecined Sections: 2 0.22%
    04:04:29 Found Zero Mov: 99.46% 914
    04:04:29 Found One Mov: 0.22% 2
    04:04:29 Found Two Mov: 0.22% 2
    04:04:29 Found Three Mov: 0.00% 0
    04:04:29 Found Four Mov: 0.11% 1
    04:04:29 Found Five Mov: 0.00% 0
    04:04:29 The Movie is declared to progressive
    04:04:29 Starting X264 AutoResize with WIDTH of Automatic and wanted size of 193986560 bytes
    04:04:29 CRF encoding X264: F:\AutoMKV\exe\encoder\x264.exe --pass 1 --crf 20 --stats "E:\temp\.stats" --progress --keyint 250 --bframes 2 --qpmin 10 --qpmax 51 --no-psnr --ref 3 --filter -1,-1 --subme 9 --direct auto --vbv-bufsize 14000 --vbv-maxrate 25000 --me umh --no-ssim --level 4.1 --weightb --b-adapt 2 --no-chroma-me --8x8dct --threads auto --thread-input --aq-mode 1 --aq-strength 1 --psy-rd 1.1:1.0 --sar 1:1 --output "E:\temp\resmovie.mp4" "E:\temp\resmovie.avs"
    04:49:39 Finished Autosize procedure
    04:49:39 Tested total movie: 5%
    04:49:39 AutoResize movie size: 39805200 bytes
    04:49:39 Movie Width suggested: 240 value based on sample size (40.54% of original width)
    04:49:39 Starting X264
    04:49:39 Command Line 1' Pass X264: F:\AutoMKV\exe\encoder\x264.exe --pass 1 --bitrate 297 --stats "E:\temp\.stats" --ref 1 --progress --keyint 250 --bframes 2 --qpmin 10 --qpmax 51 --no-psnr --filter -1,-1 --subme 2 --direct auto --vbv-bufsize 14000 --vbv-maxrate 25000 --me dia --no-ssim --level 4.1 --b-adapt 2 --no-chroma-me --partitions none --threads auto --thread-input --aq-mode 1 --aq-strength 1 --psy-rd 1.1:1.0 --sar 1:1 --output NUL "E:\temp\movie.avs"
    04:49:39 Command Line 2' Pass X264: F:\AutoMKV\exe\encoder\x264.exe --pass 2 --bitrate 297 --stats "E:\temp\.stats" --progress --keyint 250 --bframes 2 --qpmin 10 --qpmax 51 --no-psnr --ref 3 --filter -1,-1 --subme 9 --direct auto --vbv-bufsize 14000 --vbv-maxrate 25000 --me umh --no-ssim --level 4.1 --weightb --b-adapt 2 --no-chroma-me --8x8dct --threads auto --thread-input --aq-mode 1 --aq-strength 1 --psy-rd 1.1:1.0 --sar 1:1 --output "E:\temp\movie.264" "E:\temp\movie.avs"
    05:56:15 Finished 1' Pass X264
    08:17:59 Only Movie Size: 189911248 bytes
    08:17:59 "F:\AutoMKV\exe\matroska\mkvmerge.exe" -o "E:\temp\2 1 A 3 4s.mkv" --default-duration 0:30000/1001fps --track-name -1:"2 1 A 3 4s" --aspect-ratio -1:1.304348 "E:\temp\movie.264" --title "Done with AutoMKV 0.98 http://forum.doom9.org/showthread.php?t=140178 "
    08:18:27 Final Muxed size: 191996160 bytes
    08:18:27 Encoding finished: 02:22:12 elapsed time
    08:18:27 -----------------------------------------------------------------------
    08:18:28 Script AutoCrop.log
    08:18:28
    08:18:28 Crop(0,0,592,448)
    08:18:28 -----------------------------------------------------------------------
    08:18:28 Script Resmovie.avs
    08:18:28
    08:18:28 #loadpluginstart
    08:18:28
    08:18:28 #test1
    08:18:28
    08:18:28 #importstart
    08:18:28
    08:18:28 #test2
    08:18:28
    08:18:28 movie = directshowsource("E:\2 1 A 3 4s.avi",fps=29.970030,convertfps=true,audio=false)
    08:18:28 movie = isRGB(movie) ? ConvertToYV12(movie,interlaced=true) : movie
    08:18:28 movie = isYUY2(movie) ? ConvertToYV12(movie,interlaced=true) : movie
    08:18:28 function getOrder(clip c) {
    08:18:28 order = GetParity(c) ? 1 : 0
    08:18:28 Return order }
    08:18:28 #filter1start
    08:18:28
    08:18:28 #test3
    08:18:28
    08:18:28 last=movie.Crop(0,0,592,448)
    08:18:28 fixed_aspect = 1.333333
    08:18:28 out_width = 576
    08:18:28 #Aspect_Error = 0.000%
    08:18:28 out_height = 432
    08:18:28 #resizestart
    08:18:28
    08:18:28 #test4
    08:18:28
    08:18:28 SimpleResize(out_width,out_height)
    08:18:28 #filter2start
    08:18:28
    08:18:28 #test5
    08:18:28
    08:18:28 RemoveGrain(mode=2)
    08:18:28 function Comptest(clip c, float percent)
    08:18:28 {
    08:18:28 frange=floor(14./(percent/100.))
    08:18:28 Return SelectRangeEvery(c, frange, 14)
    08:18:28 }
    08:18:28 Comptest(last,5)
    08:18:28 Script movie.avs
    08:18:28
    08:18:28
    08:18:28 #test1
    08:18:28
    08:18:28
    08:18:28 #test2
    08:18:28
    08:18:28
    08:18:28 #test3
    08:18:28
    08:18:28 out_width = 240
    08:18:28 #Aspect_Error = 2.222%
    08:18:28 out_height = 184
    08:18:28
    08:18:28 #test4
    08:18:28
    08:18:28
    08:18:28 #test5
    08:18:28
    08:18:28
    08:18:28 - - - - - - - - - - - - FINISHED JOBS - - - - - - - - - - - - - - - - -
  6. please try updating the ffmpeg build (in \exe\besweet folder)
    download the latest one from sherpya site
    thanks
    BHH
    Jan 2009
    Nigeria
    Do you have any link for it Buzz?
    thanks
  8. first one of google
    http://oss.netfarm.it/mplayer-win32.php
    BHH
    Jan 2009
    Nigeria
    Thanks, i got this one :
    http://mesh.dl.sourceforge.net/sourceforge/mplayer-win32/FFmpeg-svn-16043.7z
    i have copy/pasted it in BeSweet, going to convert again and give you the result tomorrow
    Jan 2009
    Nigeria
    Hi, after i installed FFMpeg the converter get mixed! i think, before it takes 3 to 5 hours to rip movies ( but without any audio ) now after i installed it it takes about 16 hours! and after that it shows an error and closed, so there is no any output file, just in temp folder there is a audio file of my movie ( apart from the movie ) here is the latest log, is there any hope? Thanks
    23:06:52 0.98 - - - - - - - - - - - - - START JOBS - - - - - - - - - - - - - -
    23:06:52 OS Version: Windows XP
    23:06:52 Selected Input file: E:\123 A 432143 53253532.avi
    23:06:52 Selected Output dir: E:\temp\
    23:06:52 Selected Final Name: 123 A 432143 53253532
    23:06:52 Selected Container type: MKV
    23:06:52 Selected Encoder: X264
    23:06:52 Selected Size: 185 / 1
    23:06:52 Selected Profile: 2_Pass_Balanced.xml
    23:06:52 Selected Resizer: SimpleResize (neutral soft) / Automatic
    23:06:52 Selected Filters: RemoveGrain(mode=2)
    23:06:52 Selected Deinterlacer: AUTO
    23:06:52 Selected Field Order: AUTO
    23:06:52 Enabled CRF/CQ AutoRes at 20 value
    23:06:52 Track Language 1: All Audio Tracks
    23:06:52 Audio Codec 1: Nero AAC
    23:06:52 Audio Quality 1: 0.35
    23:06:52 Audio Channel 1: Stereo
    23:06:52 Track Language 2: NONE
    23:06:52 Audio Codec 2: Nero AAC
    23:06:52 Advanced Audio Settings DUMP Track 1
    23:06:52 Nero Option Profiles: AUTO --- Encoding Mode: Quality
    23:06:52 CCT Option Profiles: AUTO --- Channel Options: AUTO
    23:06:52 Lame Settings: ABR
    23:06:52 Audio Normalization: 1
    23:06:52 Frequency: AUTO --- Tempo: NONE --- Pitch: NONE --- Other Add:
    23:06:52
    23:06:52 Extracting all audio tracks with ffmpeg
    23:06:55 Unable to determine movie properties , switched to DirectShowSource
    23:07:07 0.98 - - - - - - - - - - - - - START JOBS - - - - - - - - - - - - - -
    23:07:07 OS Version: Windows XP
    23:07:07 Selected Input file: E:\123 A 432143 53253532.avi
    23:07:07 Selected Output dir: E:\temp\
    23:07:07 Selected Final Name: 123 A 432143 53253532
    23:07:07 Selected Container type: MKV
    23:07:07 Selected Encoder: X264
    23:07:07 Selected Size: 185 / 1
    23:07:07 Selected Profile: 2_Pass_Balanced.xml
    23:07:07 Selected Resizer: SimpleResize (neutral soft) / Automatic
    23:07:07 Selected Filters: RemoveGrain(mode=2)
    23:07:07 Selected Deinterlacer: AUTO
    23:07:07 Selected Field Order: AUTO
    23:07:07 Enabled CRF/CQ AutoRes at 20 value
    23:07:07 Track Language 1: All Audio Tracks
    23:07:07 Audio Codec 1: Nero AAC
    23:07:07 Audio Quality 1: 0.35
    23:07:07 Audio Channel 1: Stereo
    23:07:07 Track Language 2: NONE
    23:07:07 Audio Codec 2: Nero AAC
    23:07:07 Advanced Audio Settings DUMP Track 1
    23:07:07 Nero Option Profiles: AUTO --- Encoding Mode: Quality
    23:07:07 CCT Option Profiles: AUTO --- Channel Options: AUTO
    23:07:07 Lame Settings: ABR
    23:07:07 Audio Normalization: 1
    23:07:07 Frequency: AUTO --- Tempo: NONE --- Pitch: NONE --- Other Add:
    23:07:07
    23:07:07 Extracting all audio tracks with ffmpeg
    23:07:09 Unable to determine movie properties , switched to DirectShowSource
    23:07:17 Number of Frames: 153307
    23:07:17 Framerate: 29.970030
    23:07:17 Movie length in Seconds: 5116
    23:07:17 Movie Width/Height: 592/448
    23:07:21 Number of Frames: 153307
    23:07:21 Framerate: 29.970030
    23:07:21 Movie length in Seconds: 5116
    23:07:21 Movie Width/Height: 592/448
    23:07:24 Source is hybrid bff and tff at 0 bff and 0 tff.
    23:07:24 Advanced Deinterlace Routines Log
    23:07:24 Analyzed 1 sections of five frames
    23:07:24 Found Interlace Sections: 0 0.00%
    23:07:24 Found Progressive Sections:1 100.00%
    23:07:24 Found Telecined Sections: 0 0.00%
    23:07:24 Found Zero Mov: 100.00% 1
    23:07:24 Found One Mov: 0.00% 0
    23:07:24 Found Two Mov: 0.00% 0
    23:07:24 Found Three Mov: 0.00% 0
    23:07:24 Found Four Mov: 0.00% 0
    23:07:24 Found Five Mov: 0.00% 0
    23:07:24 The Movie is declared to progressive
    23:07:25 Starting X264 AutoResize with WIDTH of Automatic and wanted size of 193986560 bytes
    23:07:25 CRF encoding X264: F:\AutoMKV\exe\encoder\x264.exe --pass 1 --crf 20 --stats "E:\temp\.stats" --progress --keyint 250 --bframes 2 --qpmin 10 --qpmax 51 --no-psnr --ref 3 --filter -1,-1 --subme 9 --direct auto --vbv-bufsize 14000 --vbv-maxrate 25000 --me umh --no-ssim --level 4.1 --weightb --b-adapt 2 --no-chroma-me --8x8dct --threads auto --thread-input --aq-mode 1 --aq-strength 1 --psy-rd 1.1:1.0 --sar 1:1 --output "E:\temp\resmovie.mp4" "E:\temp\resmovie.avs"
    23:07:29 Finished Autosize procedure
    23:07:29 Tested total movie: 5%
    23:07:29 AutoResize movie size: -1 bytes
    23:07:29 Movie Width suggested: -332960752 value based on sample size (-56243372.00% of original width)
    23:07:29 Warning !!! - Too low resolution. Set witdh to 208
    23:07:29 Starting X264
    23:07:30 Command Line 1' Pass X264: F:\AutoMKV\exe\encoder\x264.exe --pass 1 --bitrate 297 --stats "E:\temp\.stats" --ref 1 --progress --keyint 250 --bframes 2 --qpmin 10 --qpmax 51 --no-psnr --filter -1,-1 --subme 2 --direct auto --vbv-bufsize 14000 --vbv-maxrate 25000 --me dia --no-ssim --level 4.1 --b-adapt 2 --no-chroma-me --partitions none --threads auto --thread-input --aq-mode 1 --aq-strength 1 --psy-rd 1.1:1.0 --sar 1:1 --output NUL "E:\temp\movie.avs"
    23:07:30 Command Line 2' Pass X264: F:\AutoMKV\exe\encoder\x264.exe --pass 2 --bitrate 297 --stats "E:\temp\.stats" --progress --keyint 250 --bframes 2 --qpmin 10 --qpmax 51 --no-psnr --ref 3 --filter -1,-1 --subme 9 --direct auto --vbv-bufsize 14000 --vbv-maxrate 25000 --me umh --no-ssim --level 4.1 --weightb --b-adapt 2 --no-chroma-me --8x8dct --threads auto --thread-input --aq-mode 1 --aq-strength 1 --psy-rd 1.1:1.0 --sar 1:1 --output "E:\temp\movie.264" "E:\temp\movie.avs"
    23:08:20 Finished 1' Pass X264
    23:08:37 Only Movie Size: 0 bytes
    23:12:42 0.98.1 - - - - - - - - - - - - - START JOBS - - - - - - - - - - - - - -
    23:12:42 OS Version: Windows XP
    23:12:42 Selected Input file: E:\123 A 432143 53253532.avi
    23:12:42 Selected Output dir: E:\temp\
    23:12:42 Selected Final Name: 123 A 432143 53253532
    23:12:42 Selected Container type: MKV
    23:12:42 Selected Encoder: X264
    23:12:42 Selected Size: 1 CD / 1
    23:12:42 Selected Profile: 2_Pass_Balanced.xml
    23:12:42 Selected Resizer: SimpleResize (neutral soft) / Automatic
    23:12:42 Selected Filters: RemoveGrain(mode=2)
    23:12:42 Selected Deinterlacer: AUTO
    23:12:42 Selected Field Order: AUTO
    23:12:42 Enabled CRF/CQ AutoRes at 20 value
    23:12:42 Track Language 1: Stream #0.1: Audio: ac3
    23:12:42 Audio Codec 1: Nero AAC
    23:12:42 Audio Quality 1: 0.35
    23:12:42 Audio Channel 1: Stereo
    23:12:42 Track Language 2: NONE
    23:12:42 Audio Codec 2: Nero AAC
    23:12:42 Advanced Audio Settings DUMP Track 1
    23:12:42 Nero Option Profiles: AUTO --- Encoding Mode: Quality
    23:12:42 CCT Option Profiles: AUTO --- Channel Options: AUTO
    23:12:42 Lame Settings: ABR
    23:12:42 Audio Normalization: 1
    23:12:42 Frequency: AUTO --- Tempo: NONE --- Pitch: NONE --- Other Add:
    23:12:42
    23:12:42 Extracting audio track 1 Stream #0.1: Audio: ac3 with ffmpeg
    23:16:26 Encoding E:\temp\audio1_ff.ac3 to NeroAAC with 0.35 quality
    23:29:59 Unable to determine movie properties , switched to DirectShowSource
    23:30:21 Number of Frames: 153307
    23:30:21 Framerate: 29.970030
    23:30:21 Movie length in Seconds: 5116
    23:30:21 Movie Width/Height: 592/448
    23:58:06 Source is declared tff by a margin of 50/55.
    23:58:06 Advanced Deinterlace Routines Log
    23:58:06 Analyzed 919 sections of five frames
    23:58:06 Found Interlace Sections: 4 0.44%
    23:58:06 Found Progressive Sections:915 99.56%
    23:58:06 Found Telecined Sections: 0 0.00%
    23:58:06 Found Zero Mov: 99.56% 915
    23:58:06 Found One Mov: 0.33% 3
    23:58:06 Found Two Mov: 0.00% 0
    23:58:06 Found Three Mov: 0.00% 0
    23:58:06 Found Four Mov: 0.11% 1
    23:58:06 Found Five Mov: 0.00% 0
    23:58:06 The Movie is declared to progressive
    23:58:06 Starting X264 AutoResize with WIDTH of Automatic and wanted size of 734003200 bytes
    23:58:06 CRF encoding X264: F:\AutoMKV\exe\encoder\x264.exe --pass 1 --crf 20 --stats "E:\temp\.stats" --progress --keyint 250 --bframes 2 --qpmin 10 --qpmax 51 --no-psnr --ref 3 --filter -1,-1 --subme 9 --direct auto --vbv-bufsize 14000 --vbv-maxrate 25000 --me umh --no-ssim --level 4.1 --weightb --b-adapt 2 --no-chroma-me --8x8dct --threads auto --thread-input --aq-mode 1 --aq-strength 1 --psy-rd 1.1:1.0 --sar 1:1 --output "E:\temp\resmovie.mp4" "E:\temp\resmovie.avs"
    00:43:22 Finished Autosize procedure
    00:43:22 Tested total movie: 5%
    00:43:22 AutoResize movie size: 39750976 bytes
    00:43:22 Movie Width suggested: 800 value based on sample size (135.14% of original width)
    00:43:22 Starting X264
    00:43:22 Command Line 1' Pass X264: F:\AutoMKV\exe\encoder\x264.exe --pass 1 --bitrate 1063 --stats "E:\temp\.stats" --ref 1 --progress --keyint 250 --bframes 2 --qpmin 10 --qpmax 51 --no-psnr --filter -1,-1 --subme 2 --direct auto --vbv-bufsize 14000 --vbv-maxrate 25000 --me dia --no-ssim --level 4.1 --b-adapt 2 --no-chroma-me --partitions none --threads auto --thread-input --aq-mode 1 --aq-strength 1 --psy-rd 1.1:1.0 --sar 1:1 --output NUL "E:\temp\movie.avs"
    00:43:22 Command Line 2' Pass X264: F:\AutoMKV\exe\encoder\x264.exe --pass 2 --bitrate 1063 --stats "E:\temp\.stats" --progress --keyint 250 --bframes 2 --qpmin 10 --qpmax 51 --no-psnr --ref 3 --filter -1,-1 --subme 9 --direct auto --vbv-bufsize 14000 --vbv-maxrate 25000 --me umh --no-ssim --level 4.1 --weightb --b-adapt 2 --no-chroma-me --8x8dct --threads auto --thread-input --aq-mode 1 --aq-strength 1 --psy-rd 1.1:1.0 --sar 1:1 --output "E:\temp\movie.264" "E:\temp\movie.avs"
    03:58:48 Finished 1' Pass X264
    Jan 2009
    Nigeria
    Anyone there ?
  12. Member Soopafresh's Avatar
    Jan 2004
    Just for an experiment, download the earlier 0.95 version. I've had very good luck with it. Don't change any of the files around (unless you want to use the Nero AAC audio encoders).
    http://www.download.hr/windows/file/5712/
