FYI
I've had no end of trouble with a rebuilt laptop and reached the stage of pulling my hair out trying to capture avi from vid camera without dropping frames and major jerky stuttering results.
I read all the sticky forums 2 or 3 times, check and substituted programmes and cables, defraged, deleted software, cleanups, you name it...all the moves recommended...all to no avail
In desperation I simply hooked my vid camera up to laptop with iLINK cable, booted Premier Pro which I use for all vids and believe it or not, fired up the remote storage hard drive connected with a high speed USB and guess what? Bingo, captured all vids as easy as pie with no dropped frames.
I simply didn't think the USB would handle the data especially after routing in out and round-about through the laptop etc....but there you go.
Try it, it worked for me.
				Results 1 to 1 of 1
  Simple, free ATSC capturing software?By Brad in forum Capturing and VCRReplies: 5Last Post: 25th May 2013, 19:24
  Simple task, not so simple (rip/quicksync)By Trife in forum Newbie / General discussionsReplies: 10Last Post: 12th Aug 2011, 20:57
  Need basic info on Simple profiles when capturing video with XviD codecBy snafubaby in forum Capturing and VCRReplies: 1Last Post: 19th Mar 2011, 22:54
  Adding extra material to the end of a simple 1 movie dvd (with simple menu)By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 23:38
  Simple workflow for capturing and editing HDV from my Canon HV20By pred02 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 29th Aug 2008, 09:35
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
