Is there any way to determine the size of a file produced by AutoGK in single pass mode i.e. Target Quality 75% etc, so that I can ensure that it doesn't exceed the 2GB limit?
Oh well I'll just have to hope too many films don't require multiple attempts to keep them below 2mb, unless you have any tips? I was intending to use 75% as standard so I think I should be OK up to about 2.5 hrs???Originally Posted by manono
The length of the film has nothing much to do with anything. It's how well it compresses and the resolution you use that determines the file size for the percentage you use. Yes, 75% is a good number and will give you good quality. If you know how to make an AviSynth script, then you can add this to the bottom and then encode it yourself to get a rough idea of how large the final size will be:I was intending to use 75% as standard so I think I should be OK up to about 2.5 hrs???
SelectRangeEvery(400,20)
That says for every 400 frames, take 20 (5%). By encoding a quick 5% at a quant 2.5 (roughly 75%) and taking the size you get and multiplying it by 20, you'll get a ballpark figure for the final video size. Add in the audio and a few MB for the overhead to get an idea of the final AVI size. Of course, if you knew how to do all that then you'd have no need for AutoGK, would you?
With practice you should get a pretty good idea of the final sizes of the movies before you do them. If they're noisy or grainy, brightly lit, action packed, or fullscreen, then they'll tend to be much larger than movies that are clean, dark, relatively static, and very widescreen (for a given width). But probably over 90% of the movies you do will be under your 2GB limit
x264 single pass generating corrupt AVI files
By timmus in forum Video ConversionReplies: 3Last Post: 20th Nov 2010, 13:44 -
2-pass mode - How does it work?
By Gew in forum Newbie / General discussionsReplies: 1Last Post: 25th Aug 2010, 19:35 -
mpg file size smaller than expected, TMPGEnc 2.5 VBR 2-pass mode
By chipsndukes in forum Video ConversionReplies: 1Last Post: 22nd Dec 2008, 20:48 -
Encoding single episodes from disc with AutoGK
By stantheman1976 in forum DVD RippingReplies: 8Last Post: 20th Oct 2008, 19:12 -
Using Logoaway in two-pass mode
By AlanL in forum EditingReplies: 1Last Post: 21st Jun 2007, 06:54
