Hi!
I have a subtitle file downloaded for a movie and followed this guide to make the subs for DVD: LINK but after converting with srt2sup the subtitles sync totally changed and are so useless. I checked the VOB-s created with IFOedit but the colors are also screwed up.
Any ideas how to solve this?
Thank you!
panderson
Edit: Sorry, may be in the wrong forum, please move the topic to the right place.
Try convert to sup using subtitle creator instead and see if it works better.
And if you are adding subs to a DVD you can try the wizard in Subtitle Creator, see https://forum.videohelp.com/topic338721.html -
Thank you for the idea, but this software did also desynchronize the subtitles... I'm sure I missed some options to check, but could you be so kind please to check what the problem might be?
I posted the SRT file and the created SUP file in the first post.
Thank you!
panderson
PS: May the problem be that the movie I downloaded is DivX and when converted with TMPGEnc the total frame number changes? -
Hi, I found the receip that worked for me:
TMPGEnc, Subtitle Creator and MuxMan (free)
Now the subtitles are great!
Thank you for the suggestion!
panderson
How To Add Subtitles to a DVD. (THE COMPLETE WORKING GUIDE).
By TheMatrixx in forum User guidesReplies: 653Last Post: 23rd Jul 2017, 02:40 -
Why are my subtitles not working?
By dxb_blackwolf in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2011, 00:14 -
DVD subtitles aren't working in ANY media player in Windows 7
By Chair in forum SubtitleReplies: 2Last Post: 31st Aug 2009, 08:59 -
Subtitles not working
By Dull in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 7th Aug 2008, 13:48 -
Srt2Sup - new line within subtitle problem.
By mattstan in forum SubtitleReplies: 3Last Post: 17th Sep 2007, 14:18
