i've heard that tmgenc plus' audio engine is not that great to use when concerned about quality... now tmpgenc dvd author 3 provides encoding to the mp2 format too... is it any better than tmpgenc plus' one? is it worth using over tmpgenc plus' audio engine?
also dvd-lab has the tool to convert to mp2, how's the quality of this one compared to the two mentioned? also the nero's toolkit has a converter... what's best to use? i ask specifically about the mp2 format, i know ac3 is a much better quality...
Results 1 to 1 of 1
TMPGEnc Author Keeps Re-encoding
By lostinspace00 in forum Authoring (DVD)Replies: 13Last Post: 8th Apr 2011, 09:16 -
Any way to keep TMPGEnc Author 4 from Re-Encoding video ?
By RWANDREWS in forum Authoring (DVD)Replies: 7Last Post: 3rd Mar 2009, 10:43 -
TmgEnc DVD Author Menu Problem
By powerkoala in forum Video ConversionReplies: 9Last Post: 25th Sep 2007, 14:19 -
Tmgenc DVD Author
By powerkoala in forum Video ConversionReplies: 10Last Post: 19th Sep 2007, 07:02 -
TMPGEnc DVD Author 3 - Stopping it Re-encoding
By Incast in forum Authoring (DVD)Replies: 12Last Post: 8th Aug 2007, 18:45
