Hi i have an avi file and the audio is out of sync... whats the easiest way to fix this?
cheers!
Assuming it's a DivX/Xvid file, and it needs just a linear shift (same delay as a constant throughout - ahead or behind) then try DivXMuxGUI.
I hate VHS. I always did. -
Tried installing DivXMuxGUI and it keeps coming up with a window saying i must install .net 1.1.... and to install .net framework... i click on the link and it takes me to the down load for .net 3.5 SP1 so i download and installed it and then tried the setup again but it is still saying the same thing??? why?
tried with virtualdub just shifting the audio and i can get it synced at the beginning but then it prograssively falls out of sync further as the avi continues...
how can i fix this? -
Because NET 1, 2 and 3 are all separate runtime packages. You need to install 1.1, not 3.5.Originally Posted by the_shyguy
Go here:
http://www.microsoft.com/net/Download.aspx
...and click on the link for 1.1 at the bottom of the page. After installing (including any possible reboots), go to Windows Update and see if there are any updates for any of the versions of .NET installed on your system, just to be on the safe side.If cameras add ten pounds, why would people want to eat them? -
is there any other program i can use that doesnt require .net?
i tried YAAI but it is coming up and saying that the pins are not aligned when i click on the sync audio tab??? -
Well, now this is different. As I stated, I was assuming a linear shift in my first post. There are only two repairs that I know of in this latter case:Originally Posted by the_shyguy
If you have the source:
Re-encode the video and audio separately with reliable tools for each. Avoid all-in-one's, which tend to be problematic. This is common practice with many experienced encoders. You can always mux the result together in the end with many available tools for this.
You don't have the source:
You're screwed. Kidding. :P Well, if the audio keeps straying away from one common displacement throughout, the only thing I can recommend at this point is re-encoding it with an audio editor. What kind of audio is it? You may need to convert it to .wav, stretch or contract it to the size of the video length, re-encode as such to the format you want, and re-mux.
As for .Net Framework, think of it like a language that some programs use that also saves programmers time with built-in settings. Many programs use it today, and won't install/run without it.I hate VHS. I always did.
Is it possible to fix audio sync without reauthoring?
By likwid8 in forum Authoring (DVD)Replies: 4Last Post: 13th Nov 2011, 01:59 -
avi file out of sync, still no fix.
By kiko2k2kris in forum Video Streaming DownloadingReplies: 9Last Post: 6th Dec 2009, 14:00 -
Problem with Append AVI in VirtualDub - Audio of Sync - How Fix?
By Chakra in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2008, 19:00 -
fix audio sync in dual audio avi
By jin007 in forum Newbie / General discussionsReplies: 2Last Post: 19th Jul 2008, 11:07 -
Audio is out of sync after using HDTV2DVD, how can I fix this?
By geek2330 in forum Newbie / General discussionsReplies: 20Last Post: 4th Oct 2007, 17:31
