I want to backup some of my DVDs to be able to play in my media pc which is connected to my 42" TV. I also want to be able to keep the subtitle. The only program that I have found that is able to keep the subtitle is DVDFab. Are they any other good programs that can do that? And of course I want the outcome to be the best quality as possible...the file size does not matter to me.
if all you care about is the quality then don't re-encode to anything. keep dvd video as is. copy the video_ts folder to the hard drive and call it a day. ANY re-encoding will cause a loss of quality.
help me how to make a set of avi files to DVD with menus of each avi file
By mmah in forum Video ConversionReplies: 5Last Post: 9th Mar 2011, 03:07 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 20:45 -
Create Root menu for avi's on DVD without converting each avi?
By Ghtpua in forum Authoring (DVD)Replies: 2Last Post: 8th Sep 2007, 00:23 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 13:14
