A few days ago this message has appeared when I go to the youtube web site and I cannot view any videos....
Hello, you either have JavaScript turned off or an old version of Adobe's Flash Player. Get the latest Flash player.
Has anybody else had this problem, and solved it.
I have installed the latest Java and reinstalled Adobe flash player....with no result in curing the problem
Anybody any ideas......
Java and Javascript are two separate things. Which browser are you using?
what browser? any updates to it before the message started?
sounds like a noscript or some other blocking add-on needs your permission to run scripts on yt. -
I have IE6 with XP and have checked java script is turned on, its on. The strange thing is that although youtube gives the message and I cannot view any videos.... the link to myspace to view it there, is ok.
So I wonder if youtube has altered something..... things were perfect on the 2 Jan 2009 and have done a system restore. Everythings seem ok apart from not being able to suddenly view Youtube videos.
My sons laptop with vista does not have this problem, and looking on google I appear to not be the only one with this problem of not viewing youtube. -
For any others that this may help... ......
I have solved the problem by deleting all my cookies and I emptyed my browers cache
That is after unistalling my Flash Player that was already on my computer and downloading the latest Adobe Flash Player 10.
Is this the highest possible quality for YouTube? YouTube compresses video?
By chrissyelle in forum Newbie / General discussionsReplies: 17Last Post: 5th Oct 2010, 11:33 -
Uploading a video to Youtube that will fill the ENTIRE youtube player.
By Clifurd in forum Video ConversionReplies: 16Last Post: 12th Mar 2010, 13:40 -
Problem Uploading to Youtube
By hughgogirl in forum Newbie / General discussionsReplies: 4Last Post: 29th Dec 2009, 11:42 -
MEGUI - YouTube Problem
By Cunhambebe in forum Newbie / General discussionsReplies: 4Last Post: 19th Jul 2009, 06:45 -
Youtube: Best settings for YOUTUBE in premiere pro? (encoding)
By vid83 in forum Newbie / General discussionsReplies: 6Last Post: 2nd Jun 2007, 18:52
