I just purchased a Canon HV30 camera and 2 LaCie big disk extreme triple drives. I have found that with multiple FW devices attached to my quad G5 I am unable to capture HD video from the camcorder in FCP. After 2-3 seconds of capture, the process stops and I get the message, "The end of the tape has been encountered". If I remove all Firewire devices except for the camcorder in the FW port on the front of the G5 and one of the LaCie drives in the FW800 port everything works fine with realtime capture. If I plug a single additional FW device in any port, then I get "The end of tape" message. I can't daisy chain the 2 LaCie drives-- same problem occurs. I tried to make a mirrored RAID of the two LaCie drives-- same problem. My question is:
Is this due to a limitation of the FW buses in my quad G5?
Is this due to a peculiarity of the LaCie drives?
Any idea how to fix this or is it "unfixable"?
This same problem occurs if I try to capture to an OWC enclosure with 2 drives, whether configured as 2 drives or mirrored RAID.
Thanks.
John
SD video capture seems to work even when multiple FW devices are attached. So, it seems to be isolated to HDV.Originally Posted by minidv2dvd
John
Capturing HDV Tapes using a DV Camcorder
By Raz1 in forum Capturing and VCRReplies: 6Last Post: 18th May 2011, 16:49 -
Problems Capturing HDV into Pinnacle Studio 11+
By lasereyes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 1st Mar 2009, 09:58 -
Capturing HDV in FCP problems
By editorialmoo in forum MacReplies: 0Last Post: 28th Jan 2009, 05:18 -
Question about RAID Lacie Drives and How to Use??
By Gromit137 in forum EditingReplies: 1Last Post: 24th Dec 2008, 11:17 -
Date won't appear capturing HDV (Sony HC-3)
By edong in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 15th Jan 2008, 11:49
