I captured movie from video camera in full quality. Edited it then I made avi file so I can convert it using tmpgenc. Beofre i clicked Create AVI, on the settings, there are codecs there I can use and I dont know which one to use. So then, I chose Indeo Video 5 codec as it was initially selected by default. BTW, these were the list
Cinepak Codec by Radius
DV Video Encoder
Indeo Video 5.10
Intel Indeo (R) Video R3.2
Intel Indeo Video 4.5
Of course there were on option there so display all other codecs installed in my machine but I didnt want to use DIVX as it decreases the quality. I already tried it before so I know.
But now, when i opened up tmpgenc, it says avi file is unsupported :( :( What is wrong?
Here is the details of the file i have encoded
Width: 320 pixels
Height: 240 pixels
Audio
Duration: 1:12:02
Bit Rate: 1411 kbps
Audio Sample Size: 16 bit
Audio Format: PCM
Video
Frame rate: 29 frames/sec
Video Sample Size: 24 bit
Video Compression: Indeo Video 5
Lossless codec with 64-bit (Windows) and MacOS support...
By sphinx99 in forum Video ConversionReplies: 6Last Post: 8th Feb 2010, 09:01 -
VirtuaDub Mp3 codec doesnt work (Windows 7) ?
By Chrushev in forum Video ConversionReplies: 4Last Post: 23rd Oct 2009, 02:08 -
Indeo 5 conversion
By pptman in forum ffmpegX general discussionReplies: 4Last Post: 7th Apr 2009, 14:10 -
player does not support the codec???
By angrymike in forum Capturing and VCRReplies: 12Last Post: 28th Sep 2008, 09:14 -
Help/info on IV50 "Indeo Video 5" codec....
By petruccibanez in forum MacReplies: 3Last Post: 4th Apr 2008, 00:22
