Probably a very simple question - I am looking for a tool that will author a DVD structure that is already on my drive. In other words, I don't need to add subtitles or anything, all I need is to take the DVD structure (created by DVD Shrink or similar) and burn it on a DVD R+ media so that I can play it in a regular DVD player.
I used to use Nero 5.0, I switched to Vista and Nero 5.0 does not run on it. Heard terrible things about Nero 9.0. The "burn" functionality in Windows Vista does not do the trick.
Many thanks,
Bumbrlik
I think you are using the word "author" incorrectly. Authoring simply means to create the DVD file structure out of the video, audio, menu, etc. If you have a VIDEO_TS folder, in which reside various .vob, .ifo, etc. files, then the DVD is *already* authored.
Assuming, as it seems, that you've already gotten properly-authored DVD-compliant files, your real problem is how to burn. That seems to be the real question. If so, then simply use your favorite burning tool. It's good that Nero is no longer functioning on your system.
Instead, use something like ImgBurn, which has its share of enthusiastic adherents here.
Use good media, burn a notch or two below maximum speed, handle the disc only by the edges, and disable all apps that might contend with the burner for the CPU's attention. Afterward, watch your creation and enjoy.
Adding/editing subtitles to an existing DVD without re-authoring?
By frankiewode in forum SubtitleReplies: 1Last Post: 2nd Nov 2010, 20:43 -
DVD structure
By gbabione in forum DVD RippingReplies: 6Last Post: 19th May 2010, 23:41 -
HD DVD Disk Structure?
By wulf109 in forum Blu-ray RippingReplies: 4Last Post: 7th Jan 2009, 00:58 -
Existing Mpeg2... easy authoring to DVD with Subtitles
By durexlw in forum Authoring (DVD)Replies: 3Last Post: 23rd Sep 2008, 17:47 -
Authoring a new DVD from existing one
By TheShadow87 in forum MacReplies: 5Last Post: 4th Mar 2008, 11:36
