Hi, I have 2 clips I'd like to join, one is a short video I recorded with my camcorder in DVD Video format (MPEG-2/AC-3) and the other is a long recording captured with the DOS emulator DOSBox. the problem is that the 2nd file is encoded with ZMBV (DOSBox's video codec) which is lossless and I'd like to keep it that way. I don't care encoding the 1st file at all, but I don't know if I can encode it to match the DOSBox recording which has 70.08630XXX frames per second at 320x200.
I tried using both VirtualDub and AviDemux to join and/or encode the clips but couldn't get them to match.
So basically what I wish to know is:
Is there a way to join different video files without matching them? And if not, is there a way to make the first clip (camcorder) match the second one?
And if non of these possible, what lossless codec I should use to re-encode both files and how do I match the different frame rates (25 FPS and 70.08630XXX FPS)?
Damn, I feared as much
Anyway after a LOT of trial and error I managed to get a reasonable result, here's what I did eventually:
Opened the vob file with AviDemux (because vdub can't process AC3) and encoded the video as huffyuv and audio as wave (PCM).
opened the resulting file with VirtualDub, selected the part that I need, cropped the display area to 320x200 (filters>null transform) changed the audio sample rate to 22050 Hz (audio>conversion) because 22050Hz PCM is what is used in the other video. Converted the frame rate to 70.086 FPS (video>frame rate>frame rate conversion).
for video compression I used TSCC which is a commercial lossless codec from TechSmith that is optimised for this kind of video (screen capture) and produces an extremely small size.
The reason I didn't use TSCC with AviDemux is because I couldn't find a way to change the video codec to anything but the internal codecs (I've only used AviDemux for 2 days).
For the second video I only changed the video compression to TSCC (which is even better than ZMBV(I.E. same quality, smaller size)) and the frame rate to 70.086 (video>frame rate>source rate adjustment)
I hope this would help someone else with the same problem.
[edit]
Oh, I forgot to thank you, minidv2dvd, for the quick reply
joining edited clips
By gargoyle62 in forum EditingReplies: 1Last Post: 22nd Nov 2011, 21:10 -
Help for adding Fade In/Out and Joining many clips together
By joberrick in forum EditingReplies: 1Last Post: 11th Jul 2011, 20:44 -
Joining several .MOV clips
By natty in forum EditingReplies: 18Last Post: 28th May 2009, 11:27 -
Avidemux - joining two Xvid clips resulting in one Divx video, why?
By tigerb in forum Newbie / General discussionsReplies: 5Last Post: 29th Apr 2009, 16:10 -
joining avi clips
By natty in forum Newbie / General discussionsReplies: 2Last Post: 26th Jan 2008, 12:32
