Is there a program out yet that will convert a whole DVD into a single file, complete with menus and everything?
I see that MKV is able to do chapters and subtitles. How long before it can do menus as well?
You probably won't like this answer, but... you can have the software create an ISO disc image. That's basically an exact copy of the DVD, menus and all. The downside is that it'll require at least 5-10GB to store, unless you use DVD Shrink or DVD Rebuilder and other utilities to compress the DVD further, throw out things you don't want.
However, once you've ripped the DVD and stored it as an ISO, there are a number of players you can use to play from the ISO, and you can also convert directly from the ISO or from the files within it to another format.If cameras add ten pounds, why would people want to eat them? -
What I'm wanting to do is put our training video library on a network drive. The DVDs either tend to come up missing or an instructor will swear a certain DVD doesn't play in the DVD player. I need the menus because the class might only need to see a certain chapter in a DVD and not the whole hour-long DVD.
I'm mainly a database programmer. I know nothing about programming codecs or converter programs. I might have to look into it myself though if nothing surfaces. I'll take a look at the ratDVD program. Thanks. -
Why not save the chapters or separate menu selections as individual videos, then? That way, all the instructor would have to do is call up/request the relevant video files and play them.
I believe that can be done with ISO as well, but having an instructor request (by networked computer) and play a 4+ GB file across the network could be more of a hassle.(Even assuming there wouldn't be more than one request/play at a time.)
That's probably the only sensible alternative right now, huh? I could write the program that would play the individual chapter files. It just might work...
Single .VOB file into working DVD?
By AHK in forum Authoring (DVD)Replies: 14Last Post: 5th Sep 2011, 11:38 -
dvd burning with a single vob file
By rtr720 in forum Authoring (DVD)Replies: 1Last Post: 17th Jan 2010, 03:22 -
How to get a DVD title into a single file
By Case in forum ffmpegX general discussionReplies: 5Last Post: 21st Apr 2009, 04:28 -
DVD main title to single file, with AC3/DTS
By knight76 in forum DVD RippingReplies: 5Last Post: 27th Feb 2009, 10:30 -
dvd to a single avi file
By makapa in forum DVD RippingReplies: 1Last Post: 30th Oct 2008, 11:40
