Hi folks, first time poster to this forum. I did a search for audio sync vista 64 on the site but couldn't find anything, so I'm posting.
Computer specs:
Vista 64
Core 2 Quad 2.8
Nvidia 8500
Problem:
I've been converting all my DVD and Blurays to mkv files under H264/AC3 format to view on my HTPC. The problem I am running into is that all the Bluray movies I make into H264/AC3 MKV files have serious audio sync issues when I watch them under Windows Media Player or Media Player Classic (32 or 64 bit editions) (Home Cinema). The only player they play properly in is in VLC, but VLC doesn't use hardware for the decoding so the video is sometimes very choppy. I only notice it on the Bluray rips. I did a bit of digging and found that this is a known issue under Vista 64 and 1080p files with AC3 audio and from what I gathered it has to do with Haali splitter still being 32 bit and having issues with the ffdshow filter.
So if I can't use MKV files on my computer for Bluray movies anymore, what other option could I use? MP4? But MP4 doesn't support AC3 5.1 surround files, and I can't seem to play AAC 5.1 files from my HTPC as it just gives horrible noise. So am I out of options until someone finally makes a 64 bit Haali splitter 5 years from now?
I can't downgrade to Vista 32 because it's just horribly unstable - it crashes all the time on my Home Theater app and when running the MSDE database for my dvd library. I guess I could live with MP4s and stereo AAC sound, so that might be what I end up with if there's no other feasible options.
Store all M2TS/MKV/TS/TRP.... in your computer....
Get a M6500A or limHD310s and plays those file with it via - Network, USB2.0 transfer or FTP
Note: DATOptic.com, they will give a software to convert any DVD/BR to H264 codec (MKV, TS or TRP).
There are too many codecs and it's confusing -
Thanks for the suggestions so far guys.
Baldrick: I disabled the ffdshow ac3 decoder and installed AC3filter. It doesn't seem to help at all
I know it's working because I see it in the systray, but the sound continues to fall behind. I also downloaded and tried SMPlayer with the same result. It seems that as long as the player is using hardware decoding to play the 1080p H264 video in the mkv container, the audio continues to lag behind. Only the software renderer like VLC seems to get by this probably because it uses its own builtin decoder?
FireWire2: I wish I could just leave the m2ts files as they are but they're all 30 or 40+ GB files. Transformers alone is 43 GB, which is why I've run them through eac3to and MeGUI to get them down to 8GB files so I don't run out of disk space.
I just used Handbrake to run the H264/ac3 mkv file through into a MPEG-4(ffmpeg) instead of H264 and ac3 mkv file and it plays fine in everything. Reconverting 20+ Bluray movies is now gonna take a while and I'm gonna lose a noticeable amount of quality in the picture. I still don't understand what the issue with H264 at 1080p inside MKV files are, hopefully someone solves it in the future.
Audio sync issues - H264 and AC3
By xtrattitude4u in forum Video ConversionReplies: 0Last Post: 6th Sep 2011, 02:22 -
Simplest way to convert 1080p h264 mkv to 720p mkv?
By aer in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2011, 10:16 -
Strange AC3 mkv sync issues
By MarkyMarky in forum AudioReplies: 6Last Post: 6th Jan 2011, 08:40 -
Converting an 1080p MKV (AVC1 H264 with DTS audio) to an AVI
By cpaqf1 in forum Video ConversionReplies: 5Last Post: 22nd Jun 2010, 21:50
