I have questions:
What will you see if you edited a QVGA or a VGA resolution video and to be viewed on a TV (which in NTSC format)?
Is it chunky? is it blurred? Because I'll edit a movie with a low-resolution camera (low budget) and I have VGA resolution digital camera at 30fps. I'll present it to my prof.. My only worry is having low-quality frames.
Thanks.
Explain what you mean by (QVGA = 320x240?) or (VGA = 640x480?) resolution? What bit depth? Uncompressed?
640x480 can be higher resolution than NTSC but resolution is only part of picture quality. Most "low resolution" cameras don't fill the 640x480 raster with quality video. Key issues are lens, chroma separation, optimal RGB processing.
640x480 camera example 1 $30 (poor quality)
640x480 camera example 2 $23,000 (high quality)
352x480 can look quite good on NTSC TV when interlace is preserved from the camera to the encoded file. 320x240 must be progressive and needs upscaling to 320x480 for interlace conversion to NTSC. This can cause blocking on edges and other upscale artifacts.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about
Encode video with different luminance resolution and video resolution
By kylix999 in forum Video ConversionReplies: 14Last Post: 6th Jun 2012, 07:57 -
Auto adjusting screen resolution to video resolution
By Computer Nerd Kev in forum Software PlayingReplies: 11Last Post: 11th Jul 2011, 06:36 -
What's the TV resolution when plugging a PC to the VGA port of an LCD TV?
By the_importer in forum DVB / IPTVReplies: 8Last Post: 8th Jul 2011, 22:50 -
VGA-Out resolution?
By therock003 in forum Newbie / General discussionsReplies: 5Last Post: 22nd May 2009, 13:08 -
What Windows resolution for viewing 720/1080 MKV's?
By leopardx in forum Newbie / General discussionsReplies: 3Last Post: 9th Apr 2009, 19:43
