i download some movies from the internet and their .iso format.
how do i play them on dvd player?
their about 5gb each. so im guessing it dvd format already.
do i have to encode to play on dvd player or can i just burn directly? thanks for all help
It's members like this that cheapen this forum...
Nevertheless, to make it worthwhile for those actually interested in the ISO format as a productive tool, instead of something you want to play downloaded from some bittrorrent site, think of it as a "digital DvD" designed to make your computer think it's a real physical DvD, but you don't have to go through the trouble of actually burning one. You can keep one as a Master from your productions for subsequent burns, or create one just for testing (without burning a "real" one, yet).
An app like Daemon Tools, which is a "digital DvD drive" was also designed to make your computer think it's a real DvD drive - and you can just load ISO discs into it like any player.
Some software, like VLC, just play ISO files straight without any loading or installing of any image drive.I hate VHS. I always did.
Tool recommend for *.avi ---> DVD(iso) and ripping a DVD to *.iso file?
By pxstein in forum Authoring (DVD)Replies: 4Last Post: 11th Jan 2011, 15:51 -
Does the wdtv media player handle dvd pal iso files?
By yoda313 in forum Newbie / General discussionsReplies: 4Last Post: 12th Dec 2009, 12:34 -
GUI for DVDAuthor burning iso to dvd player no menu audio
By opti280 in forum Authoring (DVD)Replies: 13Last Post: 8th May 2008, 20:11 -
problem playing burned .iso dvd in my dvd player
By method in forum DVD RippingReplies: 6Last Post: 5th Dec 2007, 06:12 -
Standalone DVD Player to read iso image and VTS files
By bluemoss in forum DVD & Blu-ray PlayersReplies: 6Last Post: 19th Nov 2007, 14:45
