I download a lot from youtube in theri newly supported high quality mp4 format.
Since these files are not insertable into powerpoint i need to archive them into another format such as avi or mpeg 1 or 2 etc.
I want your recommendations on what wouud be the best format to convert to that would yield least loss on encoding/conversion. Disk space no problem but to be practical i'd like sugestions on the most optimnal format to archive with specifications such as the bitrate VBR/CBR (IN CASE OF MPEG) or the codec in case of pure avi
Here are the characteristics of the files (except for length all files have roughly the same chracteristics of frame rate and bitrate.
Please recommend a converter otr encoder to do so if you do not mind.
*** Video ***
Duration: 00:02:18.738
Frame rate: 31.513 (2623200/83243) fps
Frame size: (480, 360)
Step: 960
Image origin: TopLeft
Pixel format: YUY2
Bitrate 520 kbps
*** Audio ***
Samples per sec: 44100
Channels: 2
I'd just keep them as they are and forget powerpoint
These are the video formats PP can use: http://kb.wisc.edu/helpdesk/page.php?id=3818
You could try XviD4PSP, WinFF or SUPER for converting if PP won't work with your present format.
Or if the videos are FLV format at present, you may be able to use them without conversion: http://kb.adobe.com/selfservice/viewContent.do?externalId=tn_14235&sliceId=1
Convert to MP4 format
By dvrvarma in forum Portable VideoReplies: 7Last Post: 7th Mar 2014, 12:09 -
Online Archival Format
By swiego in forum Video ConversionReplies: 7Last Post: 12th May 2012, 07:23 -
What format u recommend i convert to for editing?
By vannhat in forum EditingReplies: 4Last Post: 25th Nov 2010, 17:16 -
pls recommend free program that reformats the ASPECT RATIO of flv files
By iDarren in forum Video Streaming DownloadingReplies: 5Last Post: 6th Jul 2010, 03:48 -
need convert to a specific format for a mp4
By james_patageul in forum Video ConversionReplies: 7Last Post: 6th Jul 2009, 04:50
