Hey fellas,
I posted this on another forum as well, so some of you may have seen the following, verbatim. So just letting ya'll know, im not a bot
Anyone know why this is happening? With x264/h264 its fine, but these formats, while in sync and watchable, stutter from time to time and drop frames, and its not completely smooth. Im using Kmplayer (without the transform filter turned on, because it lags the vids and i dont like using it anyway), and in Overlay Mode, and they run perfect with that, but i prefer to use VMR9, because of the small color difference, nor do i need to worry about messing with brightness/contrast settings to offset what the overlay mixer will do.
Im decoding the MPG2s via Cyberlinks MPG decoder, which supports DXVA. My system is more than powerful enough to handle extreme res and bitrates, so i cant figure out why thats happening. Im actually getting DXVA when they lag/stutter via VMR9, as i can tell from the cpu usage being very low, so im guessing its some kind of decoder or player problem. Using Haali's Splitter as well, and tried it without to troubleshoot the issue and still, same thing.
Is it just that these formats dont work well with VMR9, or do i possibly need some update to it?
I have found that sometimes AC3 decoders cause problems with the video jerking like you describe. You might try demuxing one of your videos and playing just the video stream to see if that makes any difference.
Have you tried using MPCHC? That is currently my favorite media player.
Dropping frames on New PC
By beammeup in forum Capturing and VCRReplies: 9Last Post: 16th Apr 2012, 12:36 -
need help unblending previously blended frames rather than dropping frames
By BilboFett in forum Video ConversionReplies: 15Last Post: 12th May 2011, 22:15 -
Dropping frames while converting to .dv
By Huntr777 in forum MacReplies: 1Last Post: 10th Jun 2009, 17:19 -
DivX Dropping Frames? But Why?
By Anakin in forum Video ConversionReplies: 5Last Post: 12th Apr 2009, 02:25 -
New Computer Dropping Frames
By bthig in forum Capturing and VCRReplies: 20Last Post: 14th Jul 2008, 16:06
