  1. Member MI6's Avatar
    Aug 2004
    MACEDONIA
    I have DVD player that can read DivX files.I want to put about 5-6 DivX films but with menu just like authoring DVD's with MPEG files .Is it possible, and if it is what program I should use for that.
    Regards.
    QUALITY HAS A NAME
    If your player supports divx ultra it's possible, use https://www.videohelp.com/tools/sections/authoring-divx .
  3. Member ricardouk's Avatar
    Mar 2005
    Portugal
    most divx compatible players will present a simple menu where you can choose which video to play, i personally wouldnt bother with it since those simple onscreen menus are more than enough to choose which movie to play.
    If you want to convert a dvd with menus to divx with menus have a look here:
    http://forum.doom9.org/showthread.php?t=109622
    I love it when a plan comes together!
    Mar 2006
    Canada
    Thanks for the post I was looking for the same thing.
