I downloaded a movie and after unrar and unpack from bin, it turns into 5 folders:
Cdi - no content
Ext - contains 2 xxx.vcd files
Mpegav - contains 1 large xxx.dat file of 400MB
Segment - no content
Vcd - contains 4 xxx.vcd files
Can anybody give me an idea how to view the movie on the computer?
Is it necessary to burn it first?
I'm a newbie and thanks in advance for your guidance.
Either you burn the bin to a cd and then it should get a VCD/CD-I or you try to open the dat file with the windows media player as it should be a mpeg1 file
What you should ideally do. Is go to the TOOLS page and download VCD GEar gui. This will let you convert the .dat file back to an Mpeg. Then follow the instructions under the AUTHOR heading and burn your VCD back out using the Mpeg file, and oyu could disregard the other files and file structure.
Or, you can burn the bin file directly using CDR Win, etc. See under AUTHOR~~~Spidey~~~
"Gonna find my time in Heaven, cause I did my time in Hell........I wasn't looking too good, but I was feeling real well......" - The Man - Keef Riffards
What is the DAT file?
By coody in forum Video ConversionReplies: 3Last Post: 22nd Mar 2010, 20:29 -
How to view a divx movie full screen ?
By jedy in forum DVB / IPTVReplies: 4Last Post: 8th Apr 2009, 06:29 -
Video dat file played only like audio file
By newbievideohelp in forum Software PlayingReplies: 9Last Post: 14th Oct 2008, 19:31 -
DVD Lab - Movie/Title order in connections view
By BeachNut in forum Authoring (DVD)Replies: 5Last Post: 21st Jan 2008, 16:17 -
How to extract a .wmv file from inside a .dat file
By Toastie in forum Video ConversionReplies: 2Last Post: 17th Jun 2007, 22:06
